Off To York For A Wee Break!
Me and the missus are heading to York tomorrow for a week. I've had a couple of months working on kitchen renovations and I'm fair looking to chilling out. There's a vintage vehicle display at Elvington airfield on Monday that covers avert thing from motorcycles to aircraft, so that's a must see for me. Will managed to find a micro brewery on his travels, I'll see if I can find one in the York area!
I had a graet time in York, the trip to elvingston Airfield on the first day was excellent.  There was plenty to see between aircraft, museum displays, and the vintage motorcycle gathering.  I met a really nice old man that flew Dakotas during the Berlin airlift in 1948 & 1949.  he was also interested in old motorcycles and had a couple of vincents, a 1000cc Rapide and a 500cc Comet that he has had from new.   I thought that was impressive until he told me one of his sons owns twelve Vincents!!!
The motorcycle display was very impressive, and I just had to take a picture of the old Omega that actually ran like a Swiss watch.
The highlight of my holiday was getting behind the scenes in York Minster Abbey and being allowed to wind up the clock.  It turned out that the gentleman that I bought the grandfather clock from winds the abbey clocks twice a week.
Here are a couple of photos as promised, including the turret clck from the abbey.post-124-0-78552800-1410111320_thumb.jpgpost-124-0-27931100-1410111349_thumb.jpgpost-124-0-20338400-1410111368_thumb.jpgpost-124-0-14238200-1410111376_thumb.jpgpost-124-0-03264600-1410111393_thumb.jpgpost-124-0-20182400-1410111409_thumb.jpg
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
