  On 10/29/2017 at 1:55 PM, Massimo said:
Indeed! Lever, not screw operated!
It's is a rather thick crystal but the lever press should still be ok.
I've used mine on a 3mm thick crystal and it worked fine.
Expand
Some people actually recommend these over the screw type, because they give a better feeling of the applied pressure. Personally I think that as long a press is rigid enough, and have all the needed dies, there is not much difference,
Thanks Roberto, I also love the dial color.
To repaint the bezel I read the best is to use enamel for toy models, fill the numbers and let it dry.
Then with a peg wood I can eliminate the excess, am I correct?
I'm a little scared i would create new "scars" in the bezel i just polished...
  On 11/19/2017 at 10:57 PM, Massimo said:
Thanks Roberto, I also love the dial color.To repaint the bezel I read the best is to use enamel for toy models, fill the numbers and let it dry.
Yes, but I used a cloth wrapped around a small square block of wood lightly moistened in isopropyl alcohol. Not tried just scraping it off. Always worried the paint I want to remain will come out too [emoji4]
Exactly also one of my fears... I read normally the paint it the groove stays there but... Normally with me these things always go wrong!
I'll try your method indeed!
    • Sounds like he needs to take better care of his watch, or choose one better suited to his lifestyle.
    • OK. Little panic, but I'm composed now. haha I need some support on this one, and you guys immediately noticed that. Thank you! To help us navigate the situation, I recorded a video of the case and crown: https://youtu.be/tfTLZrLiaqg?si=hIW8Jbmp1DPb9fZC The measuremen Yes, it does. There was water damage, and the two pieces (stem and crown) split up when I removed the crown. I didn't have a chance to see the assembled mechanism, but this eBay ad has the same assembly with adequate pictures. I'll try that. Quite afraid of breaking it, thought.
    • Yes: Caseback provided a helpful thread which mentioned such a stake & discussed the risks involved in its use on roller tables. As well as adhesives, there was also mention of wedging e.g. with Al foil. As the watch is not mine I feel I must go for one of the latter approaches, reversibly. Thank you, again. Thank you. Cutting a new balance staff is way beyond my capabilities both in terms of technique & equipment. I think I shall explore the possibility of 'wedging' the table's tube onto the staff (arbour?) & resort to Thread Locker if this doesn't work. If it were my watch I would be tempted to risk the punch if only for the learning experience while hoping that my attempts to find a replacement balance are successful......
    • I installed a new crystal...a glass one.  It was the last one of the set of three I had previously ordered.  After he breaks this one, I will go with sapphire. This watch has an NH35A movement that runs like a beast!!  His first crystal was completely shattered.  The latter ones were cracked.  Imagine all of that force and the watch still keeps excellent time.  Truly amazing.
    • Opinions vary on the use of the 3-sided stake/punch. You can find them in a lot of vintage staking sets. I have mixed feelings about it too. You are essentially marring the roller table, which could be considered "bad practice" (and is in fact considered as such by Henry B. Fried in his excellent book "the watch repairer's manual"). If your livelihood depends on the speed of your repair and you're not hurting the value of the piece, the use of this tool could be a "quick and dirty fix". There are however more elegant solutions and Fried mentions some. I've always opted to replace the balance staff with a suitable one.
