ETA 735 mainspring ZF873
rogart63
Not that i am stingy?  But wonder if it would make a big difference? I look at  Ranfft at ETA 735 and it says that i should have a mainsping with number ZF873 .
I then google that and then i find that ETA 2390 has the same mainspring. Look at cousinsuk . They say 735  mainspring cost £12,95  and the mainspring for ETA 2390 cost  £8 . 2390 is a little longer but has the same other sizes.  Why  does  the 735 cost more then the 2390  .  When ranfft says they are the same  but cousinsuk have 2 different mainsprings.
I don't know if these MS are the same or different but I can tell you that spare part prices have little to with the part itself. They can depend by unfathomable reasons, can be stale hence cheap, or driven by demand or rarity, so very expensive. The thing one can do is decide if worth the price for the project a hand.
Wonder what the ZF873 means on Ranfft ? Is that a special code for mainspring . can't find anything about it on google.
Manage to find a spare 2390 movement from a friend. Trying to install that MS and see what happens. As the should be the same.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
