issues with an eta 2824 automatic movement....hand-winding is great until I put the rotor on the auto plate then the hand winding is impossible....rotor spins with each turn of the crown and I REALLY need to struggle to turn the crown...issue with worn reversing wheels??..thanks
You may get lucky and get away with cleaning the reverser wheels to flush out any muck or old oil, and then relubing by immersing in a bath of 9010 diluted 1:30 with naphtha. This has worked well for me many times.
The biggest mistake with these wheels is over oiling. The 30:1 naphtha/9010 mix gets around this as the naphtha evaporates and leaves an almost microscopic coating of 9010 behind; more than that causes problems. You could also use Lubeta which is made specifically for this purpose, although ETA would rather you just replace the wheels every time.
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
