Casio Mma-200 W
I have a discontinued Casio diver who died honorably in the line of duty. It has an Ana-Digi movement with a day/date window @ 3 for the digital display. Casio can't fix or replace the movement. They are not even interested!
I am looking for options as far as replacing this movement for an all analog quartz one. Any suggestions of what might fit? Thank you in advance.
Robert
PS. The picture is not my actual watch but a twin I found on line for illustration purposes.
Hi Bob,
There are many measurements which help determine suitability.. diameter, thickness of movement, etc..For your purposes.. the most critical will be distance of middle of stem to dial face.... I would expect a watch with date function to have greater distance from dial to stem compared to a watch with only time function for obvious reasons.
For most swiss watches you can find the critical dimension in the ranfft website but unfortunately this does not have casio movts. info is listed under data.. click on 'comments on the data' for explanations. You need to find out the 'T' value.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk
Heres what I would do...
Put the dial in the case and measure as best as you can the distance from the middle of the stem hole to the rear face of the dial... this is your 'T' value (increments of 0.1mm should suffice). You need to measure the dial thickness as well, if it is thick then the movt will need higher posts for the hands.
Then give this info to your watch supplier and see if they can help. The diameter / thickness would be less critical as movement rings to suit a new movement are readily available from the supplier of the new movement... since they are plastic you can buy thicker and trim down. Your case looks big enough to take even the biggest quartz movement!
Most watchmakers who do battery changes usually have stock of movements available and if you bring your watch along they may let you try one on for size...
Don't forget to get dial and hands to suit !
While this sounds quite involved, the risk is quite minimal as quartz movements are cheap..  and the satisfaction / collness of having built your own watch is incomparable.
Anil
Hi Anil,
This is priceless information to me. I appreciate it. I reached the step where I go into purchase mode and so the search for the right movement begins!
Here is the story so far:
Originally, I thought this movement could be substituted with an 11 1/2 ligne. At the time I was trying to figure out the lay off of the case with its crown @ 4 and day/date window @ 3. And so I tried a Ronda and then a Miyota movement (I believe the 517, can't remember the other) but the day/date window was off so the numbers were not centered.  Now, I have a feeling a 10 1/2 ligne will show correctly so I will visit my local watchmaker as you suggested! And since I've now measured the stem height I can contact my supplier for the right movement and ring... Life is good!
For the record:
Interestingly the dial although seemingly big, is 28.96 mm "showing" only about 25 mm because of the chapter ring. It is also  0.43 mm thick and the day/date window is 4.16 mm from the center of the dial. The T distance is approximately 0.96 mm. The case opening is 29.27 mm and the total height from the back of the dial to a marked line on the case before the end of the threaded portion (apparently delimiting the max. height of a movement) is 2.34 mm. These are my measurements with my cheapo caliper.
I'll come back and report when and if the end is successful and hopefully with a picture!
Thank you again for your help Anil.
During research, trying to infuse new life to this watch, I came up with an interesting proposition: check out the picture below, it is almost the same dial design (no numbers, and more appealing) and same size watch. The movement is the Miyota/Citizen 2305, ligne 11 1/2 (but is doesn't look the stated size). The dial in the pictured watch (newer model) is bigger and won't fit the old one, and the hands are different (the original had the "sad duck" or Mercedes style). The new movement as opposed to the Casio original has a different symmetry therefore the holder ring will be different and there exist the possibility of different hand hole diameters (pending measurement). Also notice the crown position is @3 vs. 4 in the older model. The Alarm feature and the digital feature of the original are not present with this movement. (There is a dial version with numbers but in military style). More to come.
Edited by bobm12
By the way, I lost one of the screws/ribbets that hold the bezel spring. I made a separate thread about it. I need help finding them or at least information that leads to the same goal (I have no service data or part numbers). I appreciate anything you guys can tell me. I've been searching the net for a while without success.
Robert
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
