Smith - From Cheltenham To Essex
Hi Dean, The solution with the alum for the broken screw is good and is generally used by watchmakers from many years, but You have to take off ALL steel parts from the plate. In some movements, the post for the minute wheel, for example, is made of steel. Deeping partly the plate works too, but some marks may left on the line where the solution doesn't cover the plate. Heating the solution is needed to accelerate the process. With the years, a rich collection of screws gathers and then finding the needed screw is not a problem. But till then it will be helpfull if You get some assorted screws lot. The other option is making screws. This is usually for the ones with specific form and sizes that doesn't meet often. But the skill of making screws is something that will never be unnecessary -
Haha yes you do have to reel in your bidding enthusiasm Michael. I use a " not enough time policy " to restrict myself or else known as sniper bidding. Decide what you are most prepared to bid and place it 7 seconds before the end, cross your fingers ,job done . The price paid here i would say was top figure another day could have been $40 -
The question is did Baum and Mercier use that movement. I know they used other ebouches. I can't find any evidence that they didn't but that doesn't mean they didn't. -
Well my VARIAC experiment worked sort of. By lowering the input voltage I was able to dramatically lower the magnetic field. However try as I might I was not able to demag either anvil. Even wrapped in bubble wrap to ensure it passed through the opening at equa-distance in the hole, the ends still come out highly magnetized. So time to throw in the towel and move on to purchasing the Chinese Elma-like unit from Amazon (I don’t do Ali express since I can’t return stuff if not satisfied like i can on Amazon).
