AS/ ESA/ETA 536-121
good morning
I have been restoring a Squale divers watch and have discovered that the coil on the circuit is knackered. I have trawled the internet for information and it seems like this is somewhat of a holy grail and no one stocks replacement circuits aor movements and if there is one for sale it is at a horrific cost.
I see that people fit ETA automatic ovements instead of quartz ones but again the guy I am repairing the watch for does not want to stretch that far. I have been trying to research alternative quartz movements but have not had much luck as the suggested ones are obsolete. Has anyone come across a suitable replacement before or has anyone got a spare electric circuit for this movement going spare?
Many thanks
Andy
I believe the ETA 955 is a substitute. These are sometimes available as NOS at reasonable prices. Lots of used ones and spares about as this movement featured in lots of watches. Often badged as TAG, Longines, etc. Can be GP or plain.
If you're sure it's the coil try a generic replacement.
Good luck, Neil
Eta 955 won't work. That movement is to thin and has the wrong size hands. It's only the CWC  G10 s.k  fatboy that have the  536.121 movement. All the other normal thin g10 use the 955.112 or 955,114.
Check for old Certina  quartz movements. They have a movement that is called 750. That is a ETA movement.
Edited by rogart63
Thank you for all the helpful suggestions. I am surprised by how many alternate movements can be used but never know how to find out about them. Is there a website or somewhere on for example ETA that will list successive movements in the same family that could be used? It would be so handy if there is such a site.
Andy
  • 2 years later...
  • 7 months later...
After being issued with a CWC G10 in the 1980's I've aquired several and had the ESA 536.121 fail and sourced much of this information years ago before leaning how to effectivily strip and service mechanical movements and recently purchased a quartz testing unit. Knowing the sarcity of this this movement I collected spares but fine most of them don't show a decent pulse. Some have obvious coil damage and I'm now looking to resistance test the others since there will still be a pulse if it's a gear train problem which I now adept at sorting.
Given the coils are the weak link and quartz watch curcuits almost univerally use 1.5v batteries I'm wondering if the coil could be changed with one from another type of movement preferably ETA but possibly something else such as Ronda that supply replacement coils for their movements. Under ohms law  1.5v and a similar amount of torque(power) requirement, the amp and resistance parameters for say a 11.5"'  quartz movement chip and stepper motor aren't going to vary significantly so there must be a suitable coil avaliable somewhere that would work.
The hardest part would be soldering on the very fine wires but in practice this would mean just turning the existing solder pads molten to press in the wires. What are peoples thoughts on this because the no jewel ETA/ETS 536.121 and the amonst identical but IMO better 7 jewel ESA 9362 movements are rare, expensive but were very commonly used in many good circa 1980 watches
 e
Check this response by HSL.
In my neck of the woods, folks rewire watch coils on bench, make a DIY tool , a small motor the kind you see in toys, some sort of adaptor( hand made filed down to shape) to mount the coil core on and a role of wire, which I think most material houses carry.
Works even though not as nicely coiled as factory made ones.
Happy Christmas
17 hours ago, Nucejoe said:
 e
Happy Christmas
it's interesting to hear this but the wire size and number of turns would be required and it would be a very delicate operation. Have you any idea of the sort of set up used to do this ie wire gauge number of turns resistance values etc.
I can ask how they came up with the specifications of wire.
From the top of my head, couldn't you measure electrical resistance of a good piece of coil wire? Measure its thickness?  etc.   Get help from electrical  engineers?   Post a thread on the subject? Join an electrical forum? Google for some read on the subject?
Regs
Joe
I’ve replaced coils before by soldering, but personally wouldn’t bother trying to wind one as it’s so fine. Guitar pickup wire is much thicker and still delicate. If you are lucky and the break is on the outer, then you can unwind until you reach the break and then re-solder.
With the power (wattage) resistance ohms and voltage it can all be calculated it's just the very intricate and delicate nature of making such a small coil. I may try revarnishing a coil in the hope it seals potential scratchs how ever trying to replacing the coil on a ESA 536.121 seems to be the easiest approach. These old movements are fetching second hand prices similar to ETA 2824 mechanical movements that can be used as a direct replacement .
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
