Hi gang, it's been way too long since my last post. Been a busy Summer! I have mt grandfathers Accutron and it looks like the original or maybe second battery is as long as he wore it (circa 1970). The movement looks very clean and free. I'm a little hesitant to just plop a battery in without cleaning as Im reading that any abnormal resistance in the gear train could damage the ratchet wheel or even knock the tiny pawl and pusher jewel into oblivion when the fork starts. I have not serviced one of these but I did watch some factory videos. Interesting movements, but that ratchet mechanism makes me nervous, yikes!
Chad
Sent from my SM-G920V using Tapatalk
The original Accutron batteries were 1.35v mercury cells which have long been off the market. With a 218 movement you can usually substitute a standard 1.5v battery without issues but I believe the 214 models struggle with this. Interestingly, it looks like some suppliers have come up with a workaround for this.
I've done two Accutron repairs and in both cases I just plopped in a new battery without thinking about it beforehand. You can adjust the Index finger and pawl so that they are not contacting the index wheel before dropping in the battery but if you do that you'll have have to move them back to get the watch to keep time and getting them just right is the hardest part of the service.
Testing the movement of the gear train is a bit difficult too since the wheels are well hidden under the bridge and manipulating the index wheel (driving wheel) is not a good idea.
It's an interesting conundrum for sure; hopefully someone more knowledgeable will pipe in with some good advice.
There is a woman names Samantha on the NAWCC forum who is quite knowledgeable about Accutron service procedures. I perused all the related threads there and also downloaded the service manual before getting my hands dirty. In the unlikely event we all draw blanks here, I would suggest posting the question over there to see what they may know.
If you pull the crown out, that disconnects the pawl jewels from the index wheel but leaves the electrical circuit connected. Like this you can fit a battery without worrying about the train. If it doesn't hum with a fresh battery, tap gently on the side of the case at 3 or 9 to start it.
If all of this is good then you can blow the index wheel with a blower to make sure it turns freely before pushing the crown back in
    • Donor movement received. Now waiting for a proper & calm time slot to perform the transplant.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music.     Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero.
