Ww1 Trench Watch
Interesting watch to service. NO id but after a lot of searching found that this watch is a WW1 Trench watch & was most likely made by "excalibur" Hinged both from & rear of watch also this case  is 18ct gold
The Trench watch or wristlet was a type of watch that came into use by the military during World War I, as pocket watches were not practical in combat. The trench watch had to be rugged. Yet many trench watches were actually pocket watch conversions, with most having a clam shell back and snap on bezel. SHIELDS or SHRAPNEL GUARDS were introduced to protect the crystal of watches from damage due to life in a trench and not from artillery. It protected  the crystal from accidental breakage.
post-234-0-08700500-1406909652_thumb.jpg[post-234-0-19400700-1406909655_thumb.jpgpost-234-0-76000200-1406909656_thumb.jpg
Edited by clockboy
It's a lovely watch but I somehow doubt that it was an trench watch from WW1. If I'm wrong, I stand corrected, but I'm very sceptical about many watches of this type being military watches - unless you have actual provenance. You're welcome to read what I've written on my  watch web site at: http://www.willswatchpages.com/trench-watches.html - and, of course, you're welcome to disagree with me totally! :D
Thanks Willfly
It is just that the dates are about correct as this watch was handed down from her grandmother but not with the original strap.
It is really difficult to get an exact ID as there are no clear markings on the case but made in Switzerland is marked on the movement.
I found a web site selling this exact calibre watch as a trench watch so I presumed this was it.
I will have to do more research.
Edited by clockboy
Sorry Will the only marks that are readable are 18 with 75 at right angles which I presumed is the 18ct marks and stating that 75% is gold.
There are other really,really faint marks but I just can not decipher exactly what they are. I think the marks are letters G & S.
There is also a number 14002.
The case of this watch is very badly worn & battered.
Edited by clockboy
Interestingly enough, I've just bought a silver wrist watch with "GS" marking on the inside of the case - and it's not dissimilar in style to the one you show. "GS" in this instance stands for George Stockwell, who was a well-known watch seller and importer of movements from Switzerland. I'll have some better pics when it comes in.
This one dates from 1928.
Will,
Struggled with the macro photography as you will see attached
However found using a microscope some other numbers scratched on 38052
The case No. is 14002
Hallmark is really badly worn the first symbol has the shape of the letter C followed by the letter in lower case   r
Also leters G & S
The customer said her grandmother received the watch when she was aged 21 which we calculated as about 1928 ish
Edited by clockboy
    • Hi John, The most important parameter of the spring is the thickness. The lenght is something that one would not consider as obligatory, as relatively big variations will not affect anything in significant way. The barrel size is related to the barrel and has nothing to do with the spring. Yes, the spring is designed to work in a barrel and the size of the barrel matters, but let this parameter be chosen by the movement manyfacturer, not by the sping manyfacturer who doesn't have idea in what kind of movement the spring will work. Sometimes the washer in which the spring arrives will be bigger than the barrel and there will be no way to just push the spring in the barrel and be happy. Well, if this is a problem for somebody, then probably He is a person with to many problems that will be verry hard to help to in any way. By the way, why You are changing the spring? Is the old one broken?
    • Lets give it to the end of this month to get all the votes in, then we can call it?
    • OK, I have created a solution to the above, I have made a fake protonmail account, if you PM me I can send you the password, just click on the contact link and enter your information, this should be as secure as it gets:   Website:     Link Login: email as highlighted in above screenshot WRTArk    @   Proton.    me Password: ..........PM me and I'll let you know   Only intend to use the contacts function, not the email or anything else - we are all grown ups, please act responsibly.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
