systeman Posted June 2, 2017 Posted June 2, 2017 Hi everyone, Previously in one of my other posts I mentioned I had made my own video camera for watch repairs. Well, I used it for the first time a few days ago just to get used to it and I'm sort of happy with the results. I've still got to tweak the sensor a bit, it needs a clean. My first ever video is without voice over, but as I get used to doing videos I'll add voice overs as well. The working distance from the lens to the bench was 45cm. I've got to make a decent daylight LED lamp which will improve the depth of field and focus. This video was made using ordinary warm LED room lighting. Anyway, here's a link to the Video, I hope you like it: https://www.youtube.com/watch?v=epkBJenwxzA And here's a snapshot taken towards the end of the video. 5
BabySchimmerlos Posted June 2, 2017 Posted June 2, 2017 Great video - thanks. You got your first subscriber . So I hope for future videos. Really liked the explanatory text. And would have liked to watch how you "reblacked" the bezel. As beginner I learn a lot from such videos (e.g. taping the pusher button to prevent it from pinging around).
systeman Posted June 3, 2017 Author Posted June 3, 2017 (edited) Great video - thanks. You got your first subscriber . So I hope for future videos. Really liked the explanatory text. And would have liked to watch how you "reblacked" the bezel. As beginner I learn a lot from such videos (e.g. taping the pusher button to prevent it from pinging around). For the re-blacking some people use engravers wax, sometimes referred to as Elephant Black. Personally, I prefer to use a heat and waterproof solid paint stick such as Markal B or H. Clean all the old blacking away first then rub the stick over the legend. It'll be messy, but let it dry a few hours before wiping away the excess. Edited June 3, 2017 by systeman Added some more information. 3
ro63rto Posted May 28, 2019 Posted May 28, 2019 For the re-blacking some people use engravers wax, sometimes referred to as Elephant Black. Personally, I prefer to use a heat and waterproof solid paint stick such as Markal B or H. Clean all the old blacking away first then rub the stick over the legend. It'll be messy, but let it dry a few hours before wiping away the excess. Thanks. I'll be trying this on mine. Got it for £16 non working and it needs bezel gasket and a spare link.
systeman Posted May 28, 2019 Author Posted May 28, 2019 Engravers (Elephant Black) wax is gives a more robust finish, but when used in shallow engravings it's more dark blue than black. I prefer Merkal, letting it dry for a few days before buffing off the excess. I've also hand painted engravings with a thinned black enamel, then used very fine grade lapping paper to remove excess. 1
ro63rto Posted May 28, 2019 Posted May 28, 2019 Engravers (Elephant Black) wax is gives a more robust finish, but when used in shallow engravings it's more dark blue than black. I prefer Merkal, letting it dry for a few days before buffing off the excess. I've also hand painted engravings with a thinned black enamel, then used very fine grade lapping paper to remove excess. Thanks. Ive always used thinned enamel but this bezel has very shallow engraving so I think I'll try and get some Merkal.
