Dial Repair Discussion
You need to find someone who specialises in enamelling. I had a guy who would under take the task for enabled clock dials. Sorry I no longer have his address, all I remember is it was an address in Wales 20 odd years ago.
Cousins sell  2 different dial enamel compounds (AF Swiss or Bergeon).
i have not been brave enough to try them yet, but would like to give it a go at some point.
There are also cold enamelling kits available to the jewellery trade, I wonder if this could work on watch dials.
I have tried a few dial repair kits on clock dials. The hardest part is to match the existing colour. Most dials discolour over the years and getting a match I found very difficult. I have not attempted this for a few years but if my memory is correct dial cracks can be improved by rubbing into the crake a mild solution of bleach then rising. Test on a non showing area first if attempted. This is the kit I used: https://www.cousinsuk.com/product/dial-repair-kit.
The the best I ever achieved was as follows: I rubbed down the complete dial, and repaired any cracks. Then I sprayed the dial with a white undercoat followed by a  white enamel paint. Then I added a dial transfer. Then I coated with clear lacquer.
This is not an easy job as the least bit of dust destroys the overall look.
Dial Transfer sheets.They come in various sizes & number styles see example below.
http://www.medmaw.com/cgi-bin/medmaw/medmaw.cgi?cart_id=389203_80809&page=&session=&details=y&exact_match=on&search_request_button=y&store=parts&mall_name=muk&product=14462&
I'll ask my friend if he is interested in getting a kit. He seems to want to do the work himself which is OK with me because I have no expertise in dial refinishing.
It sounds a bit like trying to match colours of ivory on an old piano - next to impossible.
Thank you for all the suggestions.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
