1 hour ago, rogart63 said:
Yepp. You need a sharp knife. Like a breakable knife?
Thanks rogart63 I'm looking forward to this then, NOT
i must say this forum is the best why bother going on others,the chaps are so helpful, knowledge of 1000 years oldhippy has most of them :D
On 3/17/2017 at 4:31 PM, BUSAKAZ said:
Hi all, does anyone know how to remove the main spring out of the barrel as I need to replace it.
Please tell, how do you know that you need to replace the mainspring? It has broken?
I just wanted to check that it wasn't broken in fact it looks pretty clean no gunge inside a dog to open though.
That's because Seiko barrels are not meant to be opened or the mainspring replace, and if not broken are better left alone.
Yes but you still have to check them through
Actually there are better ways, first is looking at the timegrapher amplitude and pattern.
The watch wasn't working elts I would have done that first.
To check if barrell / mainspring are OK just remove the pallet fork and click. With one or two turns of the ratchet, the train must spin fast. No need to open the barrel.
Is that just newer models or something? In my limited tinkering I've opened a few barrels up to have a look, and am currently hunting down a mainspring winder so that I can get the mainspring out and clean and oil them and put them back without knackering them! I know Seiko don't recommend it but for a vintage piece I had kind of gathered that it was part of doing a proper service.
*Edit: the 7005 is not a new movement so I'm honestly interested to hear what the verdict is
[emoji848]
I believe Seiko has been using "sealed for life" barrels since many decades. Beside that is debatable if mainsprings needs to be greased (certainly not oiled), that applies to mov.ts with barrels and mainsprings designed to be opened and replaced. Seiko doesn't fall into this category. You will also have trouble finding a winder that fits well with Seiko mainsprings.
Standard thing that I've seen is (and what I'm planning to do):
Open barrel and remove mainspring, clean in some (? Can't recall) in some watchmakers paper and clean barrel and arbor in US. Put a dab of graphite grease on barrel wall. Use Bergeon No.7 (10.8mm I think?) winder, most are RH but some movements are LH and replace ms and arbor in barrel. Put three drops of (?) on top of ms, seal barrel and Bob's your Auntie's live in lover.
I would guess that this is fairly common practice with other movements too?
That's the point exactly, what you would do with other movements  is not needed with sealed Seiko barrels, you don't gain anything messing with them. If you are looking to address a real problem and a way to increase amplitude on low ends Seiko look at the non-jeweled barrel bushings (just holes in the plates) which gets ovali with time.
Pip I will let you know, I just think not checking the mainspring is like doing a service on a car and not changing the oil, maybe mark could put us right......
If you're not cannot for any reason source a new sealed replacement barrel as recommended by Seiko, open it up, clean it out, replace the mainspring if you can source one, then luricate  and reassemble the barrel.  As alluded to above, I would not refurbish a car engine and run it, with old contaminated oil when it could have been changed.
Thanks Geo I thought I was going mad :Bravo:
But in 99% of the cases that's not needed with sealed Seiko barrels, and if done with bare hands or even gloves that will just introduce debris into it. I speak from the direct experience of many hours and tries backed up by timegrapher testing. If a entry level Seiko doesn't run good, be reassured it's not the mainspring fault.
Have a read of this thread Kaz and make up your own mind.
Thanks Geo, looks like jdm has been down this road already and mark said you need to open them to check <_<
12 minutes ago, rogart63 said:
A barrel with mainspring from the newer 7s26 would work fine if you don't want to take the mainspring out?
Thanks, it looks ok visually I'm going to put it together tomorrow and give it a whirl....
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
