Hi,
Does anyone know anything about how cannon pinion friction is obtained in a peseux 7056 watch movement, I'm trying to fix a vintage rotary watch which has that movement in it. I diagnosed poor cannon pinion friction and obtained a new cannon pinion but found it just seems to "sit" on the pinion and not sort of snap into place like most do.
The watch runs but stops around 10pm when I assume friction is needed to advance the date wheel.
Any advice would be greatly appreciated.
I think your right, the cannon pinion is obviously not the correct one. Since my post I checked through my scrap movements and found a peseux 7046. I tried the cannon pinion from that and it snapped on fine.
The watch is now running but probably needs a full service. I'll have to find time for that.
Thanks very much for the info.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
