Hello Mark, hello folks,
My first time post here and I hope you can help with my small issue, I have an Omega day/date with 1151 movement. It is working perfectly in general, until I noticed something is out of order with the chrono hour counter, the subdial at 6 o'clock. If I stop and reset the chrono to zero, it looks fine, but that small  hour hand seems to keep on turning, although very very slowly, for example, in the picture here, you can see it moved  30 degrees in about 48 hours, now pointing to 1. I was wondering what might be the problem here and if this is a small fix that can be performed by a regular watchmaker, as I don't want to send it to Omega for their pricey "full service" which they always try to convince you is needed.
Thank you.
With the chronograph stopped, if you press reset does the hour hand jump back to zero, I only ask as it could be something as simple as the hand is lose on the pivot.
Hi wls1971,
You know, the hand being loose was my first thought but it seemed to be advancing kind of regularly.
I just pressed reset and it went back to 0 (12).
It could be as suggested a loose fitting hand. However it will need looking at by a qualified watch repairer. Chronographs are more complex than a normal watch so require a lot of time to strip inspect & repair. If it is the hand maybe a easy repair but I have my doubts.
Have a  look at this video. At time 2:20, Mark assembles the hour counting wheel mechanism. The way the hour counting works on this watch is that the wheel is attached directly to the mainspring barrel via a clutch mechanism. When you reset to zero, the hour hammer spins the wheel back to zero and the plastic lock engages the edge of the wheel, preventing it from turning - and activating the clutch. I suspect that plastic part is worn. All in, it's a simple repair, but it must be done by someone that knows what they are doing!
5 minutes ago, wls1971 said:
Apparently this is know as "hour hand creep", and is a know problem with the 7750 based Omega chronographs
This is a explenation from the chronomaddoxx site
http://chronomaddox.com/tzof_faq.html#Chrono_Hour_creep
Also a very plausible explanation. Once the hour hammer resets the wheel, the hammer spring (which Mark is shown fitting)  is what keeps the tension of the hour counter lock (plastic part) against the hour counter wheel. If this spring tension is off, it would have the result previously described. Too bad they use plastic for this part. I suspect they do so to minimize the wear on the counting wheel itself.
Thank you guys, these were the answers I was looking for, I watched that video yesterday but didn't know what exactly I should be looking at.
59 minutes ago, SSTEEL said:
The hour brake is only plastic, and often wears, so replace this for new, and your good to go.
Ah, if only "I" could do it :)
Just to know for myself, in Mark's video assembling the calendar, is this the plastic stopper we're talking about ?
That's it!
So thats what it is for. When I service a 7750 I always did wonder what its purpose was.  If correct a very easy fix once the hands & dial are removed that is.
Yes thats the kidney, its mostly a plastic component, but on some other calibers it can be metal, seen these on some Omega's.
Edited by SSTEEL
Yep, I also learned that Omega has updated it in later versions of the movement, which they might install in case it's brought to them for service.
Anyway, it has been more than 36 hours since I last reset the chrono, and this time the hour hand has 'creeped' only very very little, perhaps half a millimeter, here is a pic of it, it might seem that it moved more than that, but the hand doesn't exactly reset right in the middle, but more like near the edge of the white dot, so apparently it  moves at its own whim :) :
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
