Mic adapter to connect Witschi to computer?
jguitron
Hello everyone,
I was wondering if anyone has any experience or at least heard of finding a converter so that the microphone stand from a Watch Expert machine can be plugged to a computer. I recently got my hands on a Witschi. It has great fidelity and the mic is excellent. I have been using WOS for some time now and I really like it, but the shortfall is the mic.
So, I did some search of a possible adapter to connect the mic to the computer and use WOS. The mic has a 5 pin plug. I couldn't find much...
Thanks in advance!
JG
Yeah, that's a 5-pin DIN.
If the mics are passive then they would likely only use two of the five terminals. Will need to try and find a schematic which shows the "pin out" for the Witschi mic cable in order to find out how to wire an adapter cable. I will have a look, but do post one if you find one.
I can't find a diagram, but if you don't have one either then you may be able to figure it out using a multimeter.
Well I decided to go for it and give it a shot. A long shot.
Identifying the plug was very helpful, now I got a couple cables and adaptors coming my way. I'll report back either way.
Thanks much!
Would it really not have a preamp in the stand? Even my cheap Chinese timegrapher uses a preamp. You could still hook it up to a PC (I plan to try WOS as well), but you'd need some minimal external electronics to provide power to the pramp.
The output from the vibration sensor on the stand is too low for the PC to use without preamplification.  If you were to increase the sensitivity of the microphone input on the PC to compensate for the low signal, it would also boost the noise. The signal would not be usable.  I would suggest reading the thread on this forum about the Watch-o-scope project.  There is an amplifier design published by Stefan which others have built for the purpose of boosting the signal from a Witschi mike for use on a PC.  There is a suggestion by one of the contributors for an off the shelf amp that also works.  I built Stefan's amp and attached my Vibrograf B200 watch stand to it; it works marvelously well.
I think most PC mic inputs will be able to provide power (albeit at a low voltage) to allow headsets with electret microphones to work. Adds another layer of complexity when trying to figure out how the mics are wired on timegraphers though.
I think checking the watch-o-scope thread is a good suggestion as above.
Quick update: I received the adapters and was able to connect the Witschi mic into the preamp just like I have been using it with the other mic with just ok results. The amp is transmitting ok, I can see the big jump in the waveform when I tap on it. But just like @tobmack said, the signal is too weak and when I increase the preamp it boost the noise as well. Quickly compared with the clip on Korg mic and it had a discernible waveform.
This was all quick and dirty because of time restraints, I'll post pics asap.
Thanks for your input!
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
