Looking for a clutch wheel for a Lorsa 238? I think there is a G after 238 but that probably a variant of the 238.
Found one on Northern watch supplies for £2 . But the shipping to Sweden would cost me £25 ?
Isn't that very much for such a small part. You could easily put it in a envelope?
Anyone now where i could track one down?
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
