It it is really matte, sanding it won't do it. Sanding approximate brushing, for real matte you need head blasting.
However since I believe most Rolex have brushed finishing, you can use we 400 - 600 grit wet paper, and then finish with fine multi-fiber cleaning pad.
Artifex is just the brand name, they make easily 100 different abrasives.
As mentioned a lot depends on how tools are used. This clasp had many ugly scratches although not deep ones. Still some buffing compound left in the embossing.
