Lathe faceplate
szbalogh
I will need a faceplate to make modifications to a specific watch case to fit the movement or just to broaden my capabilities. It must be DIY of course :) Looking for simple designs like these:
But it is not clear what the cranks at the outboard of the clamps are used for. Are they necessary?
"But it is not clear what the cranks at the outboard of the clamps are used for. Are they necessary?"
They are like small toolmakers clamps and are used for clamping thin plates.  The slots in the faceplate allow easy positioning of the clamps/job to be turned.
10 minutes ago, Geo said:
If you know how a toolmakers clamp works it should be self explanatory.
Hehe, i only know that it is used to turn plates and such. Never used one before.
I just think that the screws at the back are to tighten the workpiece. But those other screw??? What they do?
Here's one off my Boley lathe.
You adjust the clamps until they gently grip the part that you wish to machine.  Once you have positioned the part correctly, you tighten the knurled nuts at the back of the plate to grip the part really tightly.
AAhhhhhh!  Now i got it :) That nut at the front is to adjust the clamp to the workpiece thickness, that the clamp will stay parallel to the faceplate! Thank You for the excellent pictures. Now i can see that spring as well. :woohoo-jumping-smiley-emoticon:
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
    • Welcome Tarheel, there is a lot of help on this forum...
    • Hello and welcome to the forum.    Enjoy
    • I can't find anything similar either.  All the writing on the case was a form of advertising, stem set, Swiss lever etc usually found on older watches.
