I got from a friend two russian stopwatch movements, both with broken balances. Moreower, i had one also which was half the parts missing but it has a case. So from the three i could make one working piece. Making new pivots should be an easy task now :)
But i cant find any service walktrhrough for russian stopwatches. Can you help me with that?
13 minutes ago, oldhippy said:
What is the cal number.
Well, i know nothing of stopwatches yet. I saw however that there are different brands like Agat/Acat and Zlatouski or whatsoever with the same or looking like the same movements.
It is highly unlikely you will find a walkthrough with this watch. You will have to take lots of pics as to dis-assemble the watch for reference when re-assembling. To state the obvious before dis-assemble let the power off the mainspring. There are many vids & tutorials on the net on fitting balance staffs & lubrication etc.
You probably will Szbalogh and I for one will surely appreciate it... as well as many others! :) Way to go!!
Cheers,
Bob
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
