Diy Watch Hands
I'm having a go at putting together my own watch. I brought a case of Ebay, movement, strap etc & have almost finished a dial (once I can get to grips with my dial feet solderer!) I'm now turning my attention to making some hands & so to my question!
I'm thinking of making them out of stainless steel, but will this be to hard to go over the pinions? would I be better of using copper & getting it plated?
Lee
Since this will be my first pair of hands & I want them silver in colour & ideally matt, Stainless is ideal. But it crossed my mind all the hands I've swapped over, over the years are usually a plated softer metal & I'm not sure as to how successful fitting stainless would be.
Hi Lee, you could make the hands from anything you like provided the holes are broached to the correct dimensions to give that nice push fit. As you have been working with watches for some time now you will know when you have attained the correct hole diameter just by the feel.
mwilkes I made this prototype hand out of aluminium this morning, its a bit soft but once in the case would be ideal I think. I need to get some finer files for the real ones, I couldn't get a sharp edge (any suggestions) but I'm pretty pleased with the design, its inspired by the Rolex dial in the Bloodhound SSC land speed record car.
I use the diamond files from Eternal Tools as they tend not to drag. Give Lucy a shout at http://www.eternaltools.com/ she will help you.
wow thats a fabulous link. I brought a few bits & pieces & have done another hand in alloy to get the proportions rights (and some practice) but I'm a long way off producing something I'd be happy to put on my watch so far. I have an engraving machine that I'm using to cut the ruff hand out off which saves an immense amount of time, but once you get up close & personal under the eye glass its a whole new ball game!
finally had a bit of time to cut out some stainless steel. needs a lot of work thinning it down & cleaning it up, but its a start! I ordered some diamond files, degussit & some other bits & pieces now to see how patient I am!
Lets just hope I don't get a "do you know where all the knives have gone" comment at some point!
Lee
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
