Click springs ETA no.
AP1875
OK a little embarrassed here!  i'm sure you guys have heard of this a thousand times, but i was placing the click spring back in and it has sprung off into the abyss to start a new life on my floor... I actually got it in first time however i saw Mark test the click was operating correctly by giving it a little dab with his tweezers so id thought id do the same, big mistake! I pushed too hard and knocked the click spring out of place. oh well you live and learn... I'm done searching for it now so i'll have to try and get a replacement...
I'm using a cheap 2824 chinese movement to practice on. Cousins lists a click spring as part 430 eta 2776. Is this the correct part? £5.96!
They also sell a bag of a hundred non branded springs for half the price. Would that be a better option?
A big magnet is a wonerful thing just a thought for next time ( trust me there will be a next time ). And you can never have tò many bits for your spares box.
Yep that's how I found it. I have a strip magnet on a piece of card [emoji1303]
Oh yeah, for us, ball pen haters it is a great sport: hunt those pens and disembowel them! I did to get the little ball to fix the diver bezel in a Seiko...and it works great!!! :D
PS. Where are the lovable fountain pens nowadays!! Those I collect! :)
You usually help with a tooth pick or similar with an end whittled into a flat screwdriver shape and the other as it comes, sharp. Never let go of one of your instruments: the tweezers on one side and the stick on the other...at least one of them should be controlling the spring...I've lost several before I learned that lesson so welcome to the club!
Cheers,
Bob
Cheers,
Bob
Thanks for the tip Bob.
Do you know if the part I mentioned is the correct?
HI AP,
The correct number is 430 for an ETA 2824 movement...I don't know if that is the equivalent for its Chinese counterpart but the other ETA movement you list, although it may have the same part number in the tech data, it doesn't look the same ( or may be the same size either). So, I'm not too sure what to recommend...is the movement you are working on a part by part copy of the ETA 2824 or is it a copy of the ETA 2776? Either way, it is the same number but it may be different shapes/size. I don't recall working on the 2776 so I can't tell you for sure.
Cheers,
Bob
Hi Bob, thank you for taking the time to look into my answer.
It's just a cheap 2824 movement off eBay, in terms of where all the parts are placed it seems to be an exact copy. However a couple of the measurements/part sizes do seem to be slightly off from the genuine ETA model.
I did search for the part by typing in 2824 on the cousins parts list though. I was just a little confused as it says part #430 2776. I guess a call to customer services is in order to double check.
So it is. You can't assume that any part from ETA will fit the Chinese, and vice-versa.
Edited by jdm
Cousins stocks the Chinese movement. Did you check if they have the Chinese parts? I believe a complete 2824 Chinese (Cousins part # TY2130M) at cousins goes for about 70 pounds.
Interesting Bob, I didn't realise Cousins stocked these movements
    • So that is what the last person to work on this movement appears to have done.  There was a "wad" of adhesive material in the vicinity of that hole when I took the dial off.  I was hoping to take the high road and fix the issue in the work I did on this movement. I wasn't sure if I was imagining things or not when I looked at the screw hole, but it does appear to be somewhat distended.  I had not considered the posibility that someone had forced a screw that too big in there.  I had wondered about using a technique I've applied in other applications (where the screws are in the same scale as human hands) that involves counter drilling the plug with a  reverse threaded tap.  When I've had to do that in the past, the screw has generally caught and backed out from the torque on the tap (instead of yielding and letting the tap bore into it.)  I don't like doing that, but it's saved my rear a couple of times, but the smallest bolt I've tried that on had a 5 mm head.  This is an entirely different ball of wax. I am still contemplating disolving the screw with alum, even if that means I have to stick the dial down with double sided tape until I gain the skills to actually replace the screw.
    • Hi Thomas, you should be able to find the right (or on close to beeing) in a Ronda or DCN balance staff catalogue. Cousins uk have those available as a download.
    • Hello everyone. My name is Cees (pronounced "case"). I have been working on watches for a few years now. Got down the rabbit hole when I started watching "how to" videos on watch repair when my watch broke while on holiday. I'm not interested in collecting watches, but purely in the technical side. I love fixing them and also love collecting the tools I need (or might possibly need one day...).
    • The movement is FHF, something like this. But it will not help much to find stem.  Sometimes making one is easier
    • I think they all have their pros and cons, the one I suggested is a threadlock loctite product (Loctite is now owned by Henkel), In general I use the current one that is recommended on their Loctite page (link here)   I use blue (243) for the actual crown the (stick is actually 248 which is the stick version of 243), like I said it is very convenient for using on stems. Blue holds the crown for everyday use, but can be removed if you need to with a little heat. I use the red 277 for things like stem extensions where I have no intention of ever removing it. The purple I don't use (but I have seen some youtubers use it) as I think the blue is removable so why take the risk on a weaker product.   This is interesting, and a useful bit of information to know 🙂
