Here's a small gallery of the problem I have: http://imgur.com/a/MSY2D I've tried to remove the pinion but have had no luck yet. I need to change the mainspring but cant get to it without removing this pinion. Any and all help will be greatly appreciated. Also if you know how to find the correct mainspring for watches please let me know.
What kind of watch is this? Many times you can remove the mainspring barrel without the need to remove the center wheel/cannon pinion. But that is not always the case. Regardless, how are you trying to remove it? Do you have a proper removal tool? If not, you may end up damaging the cannon pinion or the center wheel pivot.
As far as mainsprings, you need to know:
o The end type - there are several and they can be found here: MainspringEnds.jpg
You also need to know the width, the strength (thickness) and the overall length. If you have the calibre number you can often just lookup the correct size online. The width and strength can be measured in mm or if you have the correct gauge, in Dennison units.
The Canon pinion isn't stuck it's just that you don't grasp what you're trying to do. It's not a conventional Canon pinion at least conventional for a modern watch.
So older pocket watches many times do not have what we perceive to be a Canon pinion. The Canon pinion itself is driven on to a center shaft that goes through a hollow tube of the center wheel. In the case of yours we can see the center pins sticking up. Then a course you can look on the other side and see the square part. Others like the image I attached of a watch I'm doing doesn't stick up beyond the top of the Canon pinion. Then just because you don't have the square doesn't mean it's one of these can and pinions as an example I have. Then recently I saw one that was rounded on the other side making it look just like the  conventional pivot of the center wheel only a little crack revealed that it was a separate pin then of course there's the visual difference of the Canon pinion they look different.
So staking set is ideal bench block with care and a hammer. You need to put the square part with its washer into an opening into a bench block or a staking set hole so it can fall out. But you definitely have to support the plate around it. Then flat punch on the protruding part carefully tap it should just fall out..
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
