Is this a waste of cash or not
Still in LA and spare time led me back to the bay.
I found a sale of parts from an estate and was tempted.  The parts appear to be enough to put most of the watch back together but then again perhaps not.  They are for an Elgin 27 Jewel 761 automatic and cost $17.90 inclusive of postage (about £13.77). What's the verdict.  I have not owned or worked on one of these,I know it is not very valuable but looks like it may be ok if it works out and it comes with the 14 k RGP case.
Cheers,
Vic
Edited by Vich
Forgot to sign off
Being a bit of a elgin fan I'd give it a go but from the photos there seems to be a few parts missing would you be able to find them and cheap enough the 761 usually commands a high price when running and cased I know ive watched a few slip out of reach because they left my price bracket its not a cheap watch. The 761 had the durabalance which some people hate and others love because of its uniqueness but some people say its unreliable because the little weights can't be poised correctly. I would have to give it a try at least to bring it back from the dead.
Thanks for the advice CAD I have sort of made my bed now but I am intrigued by your comment about a durobalance which I was not aware of.  When it arrives I will find out a bit more.  There seems to be some stuff in the tin just out of sight, fingers crossed,
Cheers,
Vic
    • Now thats a real man's tool press 👍. I have one just like it in my back garden for when just CANT fix a watch . Its not something i have had to do yet, @Waggybut wouldn't any type of press be able to do this ? What about an adapted chain link  extractor work or a micrometer with some sleeve pushers made to slot over the ends. @Waggy Found something that could work Scott, comes with different size pins and pushers. Only bit that would need making is a round former to support the inside of the case, a piece of stout timber, bit of oak or mdf might do it. What i like about this one is the pin is pushed in, its in a sliding sleeve so it doesn't turn while its being driven. This has 4 pin sizes and 3 stumps as well so it will come in for other applications, the pins could be adapted to take other accessories from jewelling tools. I've just ordered one myself for some play time.
    • So I purchased this one based on my case number being listed. (Unless my case number is incorrect. The last digits are faint)
    • I have the same tool from AliExpress and get the same anxiety when when using it. But you have to admit it looks awesome on your tool shelf. Makes you look like a pro. 🤣 Looking at the photo of the Horotec tool, it looks equally flimsy. It probably comes from the same factory. I was thinking of using the pushers supplied with the tool and making a hand tool from a cranked jeweller's punch. I'll grind off the tip of the punch and drill a hole at the end to fit the pusher in. The cranked shank would be able to clear the watch case give a straight in-line axis to exert force to tap the pendant tube out. Should be robust enough to last several lifetimes. I wonder why nobody makes it. 🤔
    • It reminds me of Ukrainian eBay sellers of Russian watches. More often than not the listings include the phrase "Serviced by Master Watchmaker". Of course, they never are, and it should be expected. It's the most corrupt country in Europe, definitely on par with Russia. Today our tiny country (Sweden) sent them another $1 232 255 518 with no accountability whatsoever for how the money will be used.
    • Now that is taking it a bit far. You are going to need a bloody big workshop.
