Let me apologize in advance for asking about what I am sure is a rudimentary problem. I am new to watch repair and can manage some very basic processes but I am really a total hack at this point. I am trying to repair a friend's watch that uses a Ronda 515.H24 quartz movement. He sent me the watch with the second hand detached and floating around on the dial. I tried to reattach it but found that when I pressed the second hand back into place, the movement froze and the second hand rotated at the same rate as the minute hand as I turned the crown. Thinking that I damaged the movement, I ordered a replacement to give it another try (they are very inexpensive). Well, after installing the new movement to the dial and reattaching the first 3 hands (24H, Hour and Minute), everything seemed to be working just fine. When I reinserted the post from the second hand back into the center pinion, I found the same symptoms as the first try...all the hands turned at the same rate and the timekeeping froze. Does anyone have any idea what I can do differently to get my friends second hand reattached correctly? I've searched a few forums but cannot seem to figure out what I am doing wrong. Thanks in advance for any help you can offer!
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
