I purchased a Tissot visodate automatic seastar seven in working order at a bootfair. Im unable to get the back off to see its serial number!!! The instruction on the back states..." use key number 275 T " . Could anyone advise if tissot actually supply a key for these watches? Any feedback would be greatly appreciated.
When the words use key whatever appear on tissot watches they are front loaders the tricky bits removing the stem so you remove the glass hands dial and and look for the setting lever between the date ring and the outer case where the stem enters the case lift it a little with a small driver and the stem should pull out.
Edited by Cad101
Isn't those stems split stems? The tool 275 is a crystal tool much like claw tool for crystals you could buy on ebay? It has a size of 275 mm. Had a set of those Tissot tools but sold it as i had now use for it? You can sometimes buy them on Ebay.
Try pulling hard on the crown and see if the split stem comes out?
Edited by rogart63
I've had a couple and neither had a split stem unless over time the stem had warn and been replaced.
+1 CAD101.
I've had a couple of these in the past and in both cases they were one piece stems
Like CAD101 said the way into these is to remove the crystal and hands, and then lift the dial off (no screws for the dial feet, they are friction fit into the movement for this specific reason) to get access to the keyless works. You can then release the stem and withdraw it.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
