Need Fendi Watch Crystal
I am trying to help a friend of mine.  His glass crystal on a fendi watch broke.
I think the case number is 013-695.  See photos below.  Where can I purchase a replacement crystal? And what else do I need to install the crystal? I pressed the broken one out.  Did not have any glue. There is a white plastic gasket in the metal case
Many people on here use this supplier https://www.cousinsuk.com/
Give them the name and number you have which might help. Measure from 12 to 6 with a gauge to get the correct size just in case the numbers are meaningless.  You will need a watch glass fitting tool. There are many to choose from.
This type  or the little blue type in the picture which  Bergeon supply, I have been told the Chinese do a much cheaper one and is just as good. I think ebay have the cheap ones.
Edited by oldhippy
    • Hi @Roll1ex, welcome to WRT. Is there a big second hand watch market in Mumbai? I seem to see a lot of used watches and clocks on eBay coming from Mumbai.  I used to buy a watch every month from Mumbai on eBay. My mentor told me it was the best way to learn watch repair, by fixing everything that's not right.
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
