First Dial From Scratch!
Most of the dials I use are either made specific to a certain movement, or are modified to fit other movements. But this time I needed a dial that would fit a specific size case(12s case) and would also fit the movement (10s) that I wanted to install in that case.
I thought it might be better to try and make one from scratch....
I milled it out of 18 gauge Brass Sheet. I wanted the look of a triple sunken dial and milled it on my lathe to mimic that look. Since it is a pretty thick dial, I had turn a seat at outer edge of the dial to allow the movement to sit at the right depth so that the stem would line up with the tube on the case.
I'm very happy with how it turned out(pun intended) as it was my first ever attempt at doing this!
I'll update with a picture of the finished dial when I get it back from the refinishers...
Will you solder on dial feet - or do you have another fixing method in mind? If feet, what will your method be for making them?
Looks good so far!
I soldered the dial feet using my Dial Feet solder machine, basically a welder. You'll notice the file marks from removing excess solder so that the dial seats flush with the movement.
Nice looking job Don, I really appreciate quality engineering!
Have you worked out a style for the graphics?
I'm thinking a nice matt silver with either style of numbers in the following pictures...
This one I had done with a Howard movement...I posted it here in a previous post.
I like the font in this dial. It looks a little more elegant!
Finally got my custom made dial back from the "Dial Refinishers"...
They do pretty good work, but I'm kind of a perfectionist so I really notice the little flaws in their printing process...couple of wayward specs of dust caught in the finish coat and the 3 has a glob of paint in it.
All in All, it looks pretty nice, I do believe!
Not the dial, but a good shot of the Hamilton 921 movement...
Thanks Geo! I do have to say that I'm pretty proud of this watch! Everything on this piece just kind of came together perfectly! And, I was very satisfied with this strap too! It compliments the dial color very well and it looks a heck of a lot more expensive than the $15 I paid for it...
    • OK, I have created a solution to the above, I have made a fake protonmail account, if you PM me I can send you the password, just click on the contact link and enter your information, this should be as secure as it gets:     Login: email as highlighted in above screenshot WRTArk    @   Proton.    me Password: ..........PM me and I'll let you know   Only intend to use the contacts function, not the email or anything else - we are all grown ups, please act responsibly.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
    • After a 3-week work fiasco that took up 137% of my time, I was finally able to get back to restoring a G. Boley 8mm lathe I picked up on eBay. I still need to do a bit of polishing on the tailstock but it works very nicely. Before and after pictures below. In any case, when I was reassembling the motor I wasn't quite sure which side the pully attached to, or if it matters. My question is ... does it matter? The listing photo below shows it the reverse of how I have it now, but it seemed that the cord and the reversing lever(s) should be on the right away from the belt.
    • Thanks Richard.  That’s clear.   So - another question - how much latitude is there in barrel and spring sizing? Say I have have measured the ID of my barrel to be 9mm and (all other mainspring specs being equal), the closest match I can find for a replacement mainspring is listed with an 8.5mm barrel size, is it acceptable to fit the smaller spring in to the slightly larger barrel without compromising anything functionally?  I’m in this situation now with an AS 1686 which has a 9mm barrel, but the closest replacement I can find has an 8.5mm diameter listed in its specs.  I can find an alternative 9mm spring, but would have to accept a different thickness.  I’m unsure how much wriggle room is acceptable, or whether in mainspring sizing, there’s a priority - ie thickness over barrel size etc. Thanks again for any info.  Cheers, John
