Oil question once again....
mcass
I know this topic has been covered to death but I've got yet another question. With so many necessary oils and grease, even for just one movement, and as expensive as they are, is there an assortment kit available with very small quantities that one can buy?
No, however there is a store on ebay here: http://www.ebay.com/itm/Oil-Grease-lubricants-Moebius-swiss-made-to-choose-for-watchmakers-chronograph-/151144554717?var=&hash=item2330eae0dd:m:mar9MRBQY0dSFs-N1enHVHw
Where I bought mine. I scoured, and these were, 2 years ago, the cheapest prices and smallest quantities. And I haven't even used 1/4 of my oil.
I would get D5, 9010, 9415, and MX grease, at a minimum to start. I didn't get the MX through them though, I think it came in a big tube through ofrei, and was like $40. Used like a thimble of it so far...
Edit: Hope mods don't mine the ebay link, I have no affiliation.
Edited by HorologicalHobby
Every 6ish month? That sound like a long time? I replace my oils almost once  a week. And as i doesn't service that many it usually new oil in every time. I add a drop to the cup and my 2 ml  9010  have lasted 2 years and more. I have shared and sold some of my oils and grease to others that wanted to start working with watches. Did a little kit out of oils and greases and used old bottles and syringes.
  • 4 months later...
Wow, not every six months, rogart63 is bang on, replace your oils every week as they get contaminated very quickly and easily. No point in taking a chance of using bad oil after you've gone to all the trouble of stripping and cleaning your movement.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
