I purchased very nice old CAMY watch form an auction site which was serviced and sold as working, however, upon arrival the watch was not working, so being a mechanical winder I wound it, nothing so I decided to remove the back, very clean inside but the hairspring looked really out of shape so I removed the balance and the hairspring is in a really bad way, it's bent in one place and looks like someone tied a knot in it?
So my question is, can I use any hairpring to replace the damaged one, does it need to have the same amount of winds or does it need to be a CAMY replacement?  I cant repair the hairspring my hand shakes will make an even bigger mess of it that it already is?
Thanks
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
