Hi all. Just received a Breitling Chronomatic - movement is an 11-i. I know this was one of the earlier automatic chronographs.
I believe there were similar models sold by Heuer, Buren/Hamilton, etc. Similar calibers are the 11, 11i, 12, 15 and I have probably missed a few.
I'm hoping someone has posted a walkthru on one of these or similar that I can be pointed to.
I did download the tech doc from AWCI which is helpful. There are specific warnings about not messing around with certain chrono components - but I do believe I will need to do a complete teardown so any help is appreciated,
Stu
without seeing the movement in question, sometimes the warning is focussed around the Eccentric screws. Messing with the eccentric screws means you have to recalibrate all the levers after disassembly.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
