Use Of Hand Alignment Tool
So my new watch hand alignment tool came in today and I really have no solid idea of the best way to use it. I could start guessing, however, if anyone has a video or could make one it may save me from failure. Please.9baee0d50e231e48988eedaf9d87d5ea.jpg
i have the exact same piece. the way i use it: i match up the hole size in the little plastic piece to the canon pinion (so the pinion fits inside when pressed down) and use that plastic piece for the hour and minute hands. i use the solid one for the second hand. nice firm, even pressure.
so you match up only one of these little plastic wachamacallits to the cannon pinion, correct? Not one for the hour and one for the minute? Then do you hold the hand with tweezers or rodico?
i just use one size for both hands. i fit the hand initially with tweezers - usually there is enough friction to hold it in place. i've only had one that i had to use tweezers to hold.
and, again, the solid one i use for the second hand.
I have one of those, I use it to great effect by placing it over important documents, I find the documents stay where they are.
Sorry, couldn't help myself, I didn't find them as useful as others have, because the precision, i find, is lacking. But you may find that it works fine for you.  :D
Edited by Ishima
that was actually very funny. I will let you know if this works. Perhaps I will make a video of the challenge
I got that one a year or so ago. Works well for me.
Cheaper than the one with three separate pushers.
Exactly the same one I picked up from China. Waiting for a set of Seiko Diver hands to come on and then we go down the road of no return
    • The entry and exit stones have different impulse face angles  murks.
    • Depending on how much of the screw is left, you may be able to screw it further in and it may fall out of the hole that the dial foot sat in. To do this I rough up the tip of the good screw and screw it in, often the rough surface of the good screw and the rough surface on the broken screw get enough of a bite to transmit the torque into the broken section and force it out the other side. Like I said the size of the broken screw needs to be in your favor, but you never know you may get lucky.... or if you get it moving you may be able to then back it out with a screwdriver taking a bite on the rough surface. worth a try
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
