Hi
I have a Rolex Datejust that has been cross threaded badly. Is there anyone that repairs these? I have a spare case back but really need the midcase repaired.
Thanks in advance.
Is it gold or steel?
If gold it can be done, if steel it'll be a hard job.
Also have you tried ultra sonicing the case to clear away any dirt in the thread? I've found this to work some miracles on watches I thought to be cross threaded.
To fix a cross threaded thread a jeweler will need to repair it.  Old school ones are the best for this, but they are really hard to source.
Thank you for your reply. It's a steel case and the thread is completely gone. The caseback simply falls off. I need someone that will add steel (laser) and rethread the midcase. Not to bothered with the caseback as I have another one.
Where do I find a watch maker that does it and what would a reasonable price be?
Hm, I don't see that job being less than £300 to do. It sounds serious.
None of the jewelers I use would be able to do that.
Some jewelers at hatton garden in london do some good jobs with laser welding, but I would not be able to tell you who'd be trust worthy as their are alot of rogues in that area.
I came across this site in the past, and they say they do that sort of repair.
http://www.classicwatchrepair.com/page4.html
But I don't know if they are legit.
thank you for the website. I'll ask a few dealers who travel to HK to check it out for me.
I will keep an eye open for a midcase if one becomes available.
Thank you again.
Great link amazing restorations
