4 Drops Of Oil
avkxyz
I would use the oil as a hand moisturizer :-)
Putting oil in a dirty watch will produce an abrasive sludge that will accelerate wear on the movement.
I suppose you could *cover* the movement in oil to prevent rust, but in that case you shouldn't let it run!
Another I got that can happen is if the old oil has turned to hard varnish, the new oil will eventually soak into it and make it swell. When this happens, the expanding varnish grips the pivots and stops the watch, this may take a week or two to manifest. This happened to me in my early days of watch servicing, all the parts had been through the ultrasonic cleaner, but there was still residue in the jewels that I had not seen. I won't make that mistake again
Without service a watch, If only gives you 4 drops of oil to lubricate a movement, where should I apply the oil to?
thank you
Lubricate pallet jewels face and balance pivots. Check a real example at http://www.watchrepairtalk.com/topic/3566-another-poor-seiko-pattern/
I do not marry the "always complete service" mantra, real life and the risk of of "mishaps" happening while trying to worship the theory taught me better.
Edited by jdm
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
