I took the blanc pain cal 1151( frederic Piguel ) movement out to clean but the hair spring come of from the balance .  I am confuse because it has 2 screws on the balance .  I want to put them back but I don't know how because this is the first time I seen this balance like this
I attach the pics of the hair spring and the balance plate
thanks
post-1739-0-32500500-1453124359_thumb.jp
post-1739-0-63113500-1453124374_thumb.jp
post-1739-0-85576600-1453124391_thumb.jp
Welcome to the forum. Better close up pictures would have been better to let people see better detail.
The HS stud should go into the outer hole. I suspect the inner screw is for fine adjustment of the rate once you get it almost perfect by pushing and pulling the rate adjuster as required first. I may be wrong, as I have not worked on one of these movements.
Google triovis regulator.
It's a precision regulator adjustment system used by IWC amongst others.
Geo is right,the hair spring stud goes in the outer hole, the inner screw is for adjustment.
