Hi,
I have a customers watch that I need to replace the dial.
The Brand is called "Prestige" but it's like they don't exist on the web.
Image below if anyone can point me in the right direction.
Many Thanks in advance
Ash
post-1752-0-13324100-1453114875_thumb.jp
