o.k., perhaps a silly question.....while surfing fleabay, i came across an auction for this ETA C01.211 movement (not that i'm gonna be buying it). but i noticed that the balance does not have a register on the adjustment. i've never seen this in a movement before, and i'm especially surprised that it's on a high end movement. why is it made like that?
Edited by ramrod
It's not a hi end movement, look at the plastic escape wheel. Although there is no register to record adjustment, if you look closely both beat and rate can be set.
LOL!! i gotta kick myself. i didn't notice that plastic escape wheel. too funny.  i only thought it was hi end because it's $290!!?? wow.
it reminds me of a seller i saw yesterday. they were a new swiss seller selling new assorted ETA movements. the shipping was $2000!!
they'll get you one way or another.
Edited by ramrod
ya' know? when you really stop and think about it, nothing is new anymore. i figured swatch had something revolutionary in 2013.....and here tissot had it back in 1971.....linking back to 1952!
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
