Hi.  I am comfortably at a level of changing watch batteries for my son, who owns quartz watches.  I replaced the battery (Renata 371) on my son's diver with a Ronda 515 movement.  The seconds hand only "ticks" back and forth between minute markers, but does not seem to change seconds.  Obviously the new battery is working so I thought it was the movement... Ordered and changed the entire movement but the replacement movement seems to just do the same thing... I am stumped.   Can anyone offer some advice?  Thank you.
Welcome to the forum.
Normally if the second hand twitches it's an indication of a seized
movement due to old oil which can sometimes be freed.
Where did you get the new movement from and is it the correct one as there are a number or variations?
Thank you, Andy.  The new movement comes from an online shop popular here in the Philippines called "Lazada".  I have had no problems with them and the claim was it was that it was "imported from Switzerland"  but the back of the movement says Swiss Parts... so, I think this is assembled in Bankok.  I got the batteries from the same online shop.  All the parts including the hands fit perfectly.  I am a bit scared to take it apart, but I have to do it sometime...
The watch is "Wenger" and that is definitely genuine.   You think I have better chances taking that old movement apart? I will start looking for the tech sheets.
I wouldn't start taking it apart unless you've no other option.
Try a drop IPA or lighter fluid on the rear pivots and see if this frees it up.
Edit
Is it possible with the new movement you've got the wrong variant and
the hands at catching the lens or does it still twitch out of the case?
Edited by AndyGSi
Thank you, again.  No, I do not have a watch tester yet.   Thank you for the link.
I will try the IPA method and see if it works.   Sounds about right... I will get back to you to let you know.
Check the battery, even if it's in a sealed  packet, aged ? a weak one could cause this seconds motion. Never assume that something unopened is fully functioning.
These cheap testers are handy little gadgets, I used one extensively when i started watch repair. Great for basic testing of circuit modules for working. Most have a quartz component check, the battery tester is pretty basic and will only provide an indication. You can buy a voltmeter cheap enough to test batteries.
They do new fangled digital ones now that actually show the voltage and an idea how accurate the movement is.
Some Quartz watches need a re set after a battery change. I have one of these which gives the option to free a clogged movement..
Did you buy that from Noah? 😄
23 minutes ago, AndyGSi said:
Just had a look at the link by @HectorLooi and think the list price is a bit of a joke.
I hate sellers like these where they show stupid discounts so peope think they're getting a bargain.
If you think the price is a joke, look at AliExpress. It's even cheaper. That's why I buy most of my stuff from AliExpress. Only stuff that I can't get from AliExpress then I'll check if Lazada has it.
I saw that but wasn't sure what brand of dollar I was looking at.
I have that one, the crystal tester is interesting, if you've ever tried it.
As per the Aliexpress thread I started. I've bought 30 items in the last month, about 40 quid in total.  Everything I've bought is available at Ebay.  This is why ebay sellers offer free shipping for these items, because they paid so little and it's an incentive for buyers. A year ago I bought a small speed controller from ebay, about 4-5 quid, 4 of the identical ones turned up on Saturday from Ali for 2 quid, 50p each.
Hi guys, thank you all for the comments.  Andy, the IPA did not work.  I decided to take it apart.  At least Ronda has the complete tech papers.   clockboy, I tried fiddling around by moving the gears, the connection is there, but the "reset" option sounds good.  I will research on it, but any hints would be well appreciated.   Neverenoughwatches and Andy, I am not sure if I want to invest even that much for a tester, since quartz movements seem really cheap... and I am lazy, hahahaha.  But I have a multitester that is very good, and it registers a good voltage on the new battery.  Thank you, Neverenoughwatches!
There is no reset on a Ronda 515 as this is only on Chronograph movements.
7 hours ago, AndyGSi said:
The listing doesn't say a great deal but would be interested to know more about it.
typical problem of the picture it doesn't really sell itself we need a description. One of the other sellers had a better description.
On 4/12/2025 at 3:12 PM, Neverenoughwatches said:
What voltage are you getting ?
I am getting 1.55 Volts on all the batteries i purchased -- directly out from the packaging.
There seems to be a way to "short" the thing to what they call an AC Reset... Makes a bit of sense, only problem is that i have  to firstly re-assemble the movement.
    • Sorry I have this thread forgotten. Now, why the stones break? Several reasons: One - the old stones are crunchy. Be careful! Two - wrong tweezers. Use brass ones. Three - wrong approach. The best way is not to grasp the stone close to working side. Grasp it for the middle part, the tweezers direction to be perpendicular to the stone. Use oscillating tilting movements when moving the stone.  Now several tips that are not read from the books, but found in my practice. They are good for my way of correcting pallet stones position: You don't need the heater for adjusting the stones position. The heater will be needed only to glue/fix the stone when the adjustment is already done.  The stone should seat tight enough in the slot without gluing. Tight enough so the movement will work normally and thus checking if the adjustment is correct is to be done before gluing. If the stone is loose in the slot, then heating and melting the shellac will make the stone move in by the capillary force. So, if the stone is loose in the slot, then find out if the stone is not correct or the slot is opened. If the slot is opened, then (in steel pallet forks) it is good idea to anneal locally only the small part that forms the slot before trying to close the slot. Also, put in the slot something slightly thinner than the pallet to limit the amount of bending If the stone must go out, the shellac can stay in place, it will not make the adjustment harder. Just bend the stone to break the bond between the shellac and stone. Then heating only will glue the stone again if the shellac is not old and degraded. If the stone must go in, then the shellac mus be removed from the slot bottom as to make space for the stone to go in. I often use pallet stones from USSR Slava alarm clock for pocket watches repair. Slava pallet stones are usually bigger (wider) than needed) and I grind/lap them to correct size for the slot. Grinding is of the side that never contacts the EW teeth. It is enough to put the stone on the lapping plate, pres on it with finger and move it forward/reverse several times while pressing, then check in the slot.
    • I used a small ultrasonic for years until it died, but it does need to be large enough to fit jars in to hold your parts, and small parts ideally are in mesh baskets within the jars so you are not fishing them out one by one with tweezers. So the one you linked might be too small and this kind of thing really the minimum workable size
    • You'll probably find when you get the dial it's slightly under the stated size to start with. Depending on the dial I'd mount it on a mandrel then spin it in a drill using a hard sanding pad to reduce the diameter.
    • Thank you @AndyGSi for the heads up. It is supposed to pressed down by a metal ring/bezel. I haven’t tried it yet. Let me check. Alternatively I may reduce the diameter of the dial, but I would need to mask/protect its face from dirt.
    • Ah, good one. I've got the crown going into a hole in steel to support it - maybe I'd be better off using plastic thinking about it...
