Hi guys,
I have troubles in decasing this vintage chrono movement.
I can remove the central stem but I can't remove the pushers.
Is there a simple way to do it?
I think the pushers will come out after you have take the movement out? Only remove the stem and movement  screws to remove the movement from the case?
Some chronometers have a screw/push button that need be dealt with to remove the pushers....maybe that is your case?
My though was that they where disassemble after the movement has been removed from the case?
Yes, that would be the most common configuration I believe. It just changes sometimes with some high end watches...at least that I've seen.
I think you'll find that the watch is a front loader. You will have to remove the stem, carefully prise of the bezel complete with crystal then undo the the case screws. When you have done this the movement should come out the front of the watch leaving the pushers in the case, although you may have to remove part of the movement to release the pushers.
Exactly! I tried what you said and it's a front loader. Only way is to remove the movement by the crystal side!
Thanks!
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
