Hi everyone, I'm trying to get some information on my grandfather's 1979 Timex watch as I would love to get it spiffed up and working again. I've read several threads on similar models and am a little confused as to what exactly applies to my case. The number on the face below the 6 is: 3422910879
1) What is the best way to source new crystal for this model? The crystal is cracked and will need to be replaced. I've found a few similar models on ebay that I could use the crystal from but they also look a little rough and I'd love to find crystal in better shape. Also, any tips on the actual replacement? Would it be best to purchase a crystal lift?
2) The watch appears to work intermittently but sometimes won't budge. I assume this means, at a minimum, it will need to be cleaned and lubricated. I've done some very basic repairs on other watches like battery and quartz spring replacement but I've never attemped cleaning and lubricaion. I will search the forum for general ideas but was curious if there were any certain things to look out for with this model.
Thank you so much for any help!
I know little about Timex other than what I've read on here.  You need to remove the bracelet for cleaning, remove the back and the movement, we can advise m , how to do so, once the back is removed.  The crystal needs removing and measuring, however, I believe that Timex had cas numbers that would tell you the crystal size.
@JerseyMo, can you help?
Timex did not maintain crystal size information.  So you will have to measure it.
28 minutes ago, watchweasol said:
Hi I believe it’s a 108 movement made in 1979.        Manual atteched
Wow... thank you so much for that!  Here's a photo of the watch with back removed.  To my uneducated eye it does look like the movement you mentioned.
18 minutes ago, AndyGSi said:
From the information I've got you need a Timex #37 lens.
Thank you both for your reply.  If it does need to be removed, would you happen to know the best way to remove this crystal for measurement? And if it is a #37 lens, is there a straightforward way to order a replacement with that info? A quick google search didn't give me an obvious answer, unless it's hiding in plain sight which is very possible.
Edited by jbslus2
typos
Looking at the case there's no bezel so it could just push out from the back once the movement has been removed but the correct way is with a crystal lift.
I think you'll be lucky to find a #37.
Here's one seller I've got marked for Timex, they've not got a #37 but do have some of the PA if you find one of these is correct.
Edit
Here's the 104 Service Manual showing cleaning procedure as mentioned in the 108 Manual.
Lighter fluid can be used as an alternative to watch cleaning fluid and then IPA as a rinse.
Model 104 Service Manual.pdf
Edited by AndyGSi
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness oil in-between . You want a short answer now,  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
