Elgin Grade 315: Runs/stops with dial down/up
😳OMG men I thought you were kidding- You’ve been duped by a bot! Rolex used those blue screws on the automatic movement to distinguish them from the plate screws. I can’t talk you off the ledge but a few minutes watching some 31xx service videos or look up the part number for the automatic mechanism screws yourself should help…
Can someone help with this please....Is this a screw back? If it is the pins would be very thin. If snap on no prize points for case knife visible. Thanks
By EtherJunky · Posted
I appreciate that I'm responding to a thread from over a month ago, and you're unlikely to have sat in front of your screen twiddling your fingers waiting for a response and probably found a solution already (like poking at it gently to see what happens), but I found a parts listing with a load of codes that maybe useful: https://www.emmywatch.com/db/movement/bulova--5at/ If that link doesn't work, I grabbed a screenshot of the full page too -
So, here we see the blued screws again! The blued screws I showed look in my opinion very cheap and not pretty. Certainly not what I would expect from a genuine Rolex. The blued screws in you picture look nicer. But again, Rolex don't use blued screws, or do they? Are you sure it's not a Chinese super clone or did you or someone else replace the screws? In my opinion it makes sense that Rolex wouldn't use blued screws, especially since they never (exception being the new Land-Dweller) expose the movement through a see through case back and even more so as these screws are fitted under the dial. The original DNA of Rolex is utility, not luxury. So, are our movements fake?
Hmm... In the picture, it looks like the spring pushes on the side of the pinion. In the Vostok 24xx movements, the spring pushes down on top of the pinion. That is, the Vostok pinion is not visible from above as it is in your picture. Perhaps the Omega spring presses on a round tab fitted on the arbor just under the pinion? EDIT: Had a better look at the following posts, and the answer is yes!
