Seiko 6139 Chrono
Evening all just got this little project in.
8228872D-D96D-43FA-8796-8F060547C1EF_zps
D7CD2CEC-2BED-41FB-96AD-AABC18778837_zps
E487E745-3A6B-4673-96BB-59D67019D22B_zps
She is a non runner and very gunked up, I have 2 questions I can find the technical manual for 6139a on cousins but I notice that mine is a 6139b (as you can just see in the above pic) what are the major differences between the a and b? Can I use the a guide or will I become unstuck!?
Second this will be my first crack at a chrono, any tips for me? Or suggestion of similar movements I could pick up cheep to practise on first?
Cheers
Yogi
Nice project, I love chronographs.
I can't make comment regarding the technical specification, but if you do go ahead take lots of detailed photos of every step. View Mark's videos on chronograph overhaul a few times, I wish I had before doing my first one.
Oh, and make sure that what appears to be a screw is a screw and not an adjuster cam!
Have fun and best of luck with it.
I was just wondering if you have started working on the Seiko?
I bought one last week and I'm in the process of picking up parts for it.
You asked about the difference between the 6139A and 6139B. I read that there were changes made to the date/day side of the watch, but the movement and chronograph mechanism is is the same in both movements.
  • 2 months later...
Just done a full refurb on Pogue (yellow face) version of this watch with 3168B movement.  Was gaining 2.5 hrs/day before service and now run for 11 days without losing a second!!
You can use the 3169A data as most of the parts are visually the same.  I think there we a few changes to the chrono wheels (58 & 47) and chrono bridge but nothing to indicate different assembly.  The following are my key points which may help you, the numbers refer to the steps in the 6139A chart you have from Cousins (if you want a coloured version then it can be found on www.scribd.com/doc/121154984/seiko-6139.)
Chronobridge (44) - 6139A/B differences are that some parts are rivetted on B but screwed on A.  No need to remove these parts just clean as-is.
Intermediate Minute Recording Wheel on chrono bridge is fixed onto post in A but is a removeable wheel in B.  This wheel is difficult to refit as the chrono bride hammer spring puts the bridge under some tension and it moves all over the place!  I used a couple of very small pieces of Rodicao to hold the wheel to the chrono bridge, fitted the bridge then carefully removed the rodico.  You only need to 'catch' the edges of the teeth in one hole and at the edge of the plate, too much and you wil have trouble removing all the rodico.  I also lubes the pivots very sparingly with Moebius 9010.  Great care is needed refitting the chronobridge as pivots cab easily be bent/damaged.
Do not remove the adjusting screws on the centre chrono wheel (58) or the first coupling lever (50)
The day finger (31) has a cut-out and a finger.  The protrusion on the Date Finger (32) fits into this cut-out NOT the hole at the end of the finger.
The intermediate date wheel (34) is small a plastic wheel with 2 cogs and the teeth can damage easy when checking motion if any tightness in setting train (I know I did it!!).  I sourced a new one and it was metal (much better!) so I think this was an A-B mod (to save money on parts cost??).
The operating lever spring (48) goes round the post in the operating lever and not the screw post (as done on an Ebay video!)
The Pillar Wheel Jumper Spring locates into the pawl at the bottom of the pillar wheel not the pillars.
The Day Corrector Finger (27) must not be trapped under the dail guard(24), pressing the crown fully in should send it to the centre of the movement. Also check that the spigot for the Day Corrector Finger is fully engaged in the dail guard (this can cuase the finger to jam under the guard).
The Dial Guard (34) has an incorporated spring for the Day Star Dial Disk (22) and must be clicked into the star inderneath the disk when the disk is fitted.
I had to replace the mainspring and used the one from the base movement as one for the A&B are no longer available.  401615 for 410616. The barrel and arbour are all the same.
Leave the pallet and balance until you have assembled the chrono etc as you can then check all is free and the chrono works, turn the screw in the middle of the barrel 1/2 a turn or so to help.
Be careful when refitting the centre second chrono hand as it is not unknown for the jewel to be pushed out, Seiko have a special movement holder.
If you are prepared to remove the case bezel (there is a notch under the bezel at 12 oclock to prise it off) and the crystal (just pops out, fitted on gasket in holding ring) then you can use the pushers etc for resetting the hands as explained in the chart which is easier than handling the movement with the dial fitted outside the case.  When done the crystal and bezel can be refitted using a case press (do not overpress, the bezel will just click into place)
I used Moebius 9010 to replace Synt-Oil-A and Moebius HP1300 to reaplce S4.  I used Moebius 8317 on the mainspring barrel.
Good tip is to search google for Seiko 6139B PICTURES and follow links, much quicker than searching text data.
Hope this helps.
Thank you canthus, very helpful she is currently sat in a box with my other stuff as I have a 3 month old to add to my 2 year old! Not got much spare time! Once it gets cold and dark again I'm sure I will crack on with this project and this info will be very useful thanks
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
