Ok I wanted to publish my findings as I ended up making a "commercial" solution yesterday and used it to clean a movement. I measured using a scale to dial in the percentages accurately. My recipes are as follows:
SwissSeiko's 111 Ammoniated Cleaning Solution
65% Mineral Spirits(Klean Strip) - Pretty standard
20% Light Naphtha(Klean Strip) - I think this is what we all have access to, but it has the same carbon atoms as the L&R 111. Dark Naphtha has more carbon, and has a much higher boiling point, which decreases its volatility at the temps and times we are using.
5% Store bought concentrated Ammonia(Ace Hardware). This is slightly less potent that pure ammonia, but it is essentially ammonium hydroxide(with slightly less ammonia per weight), which L&R calls for.
5% Kirkland Dish Soap - This one is interesting as its taking the place of Oleic Acids in L&R's formula. It has the amino acids were looking for, but with additional degreasers, and a scent that helps cover the ammonia smell.
5% IPA 99% - This takes the place of the amino alcohol in their solution, of which has propylene oxide, which i'm not sure citizens have access to, Its very toxic. It is used as a solubilizer.
SwissSeiko's #3 Watch Rinse
80% Mineral Spirits(Klean Strip)
This one is very simple and works very well
And there you have it. A commercial quality cleaning solution that can all be purchased at your local hardware store, for relatively cheap. I think if you had to buy it all at once, it would be around $65, but you could make nearly 2 gallons of it. I did a lot of research on chemical properties to try and match the medical grade chemicals they are using, but with easy availability. Obviously you need to be careful when handling chemicals, and you need to have a vast understanding of chemical reactions before you jump into making your own solution. I pulled the MSDS of all of these chemicals to make sure I understood their makeup, and to eliminate any dangerous reactions.
The results are very good. It has exceeded my expectations as a home brew concoction. Parts come out brighter than when I was using Liquinox, and that's due to the ammonia. I'm not quite ready to give up my Liquinox, but its handy to have an additional non-water based cleaning solution that works well, particularly for vintage movements, which I mostly service.
Don't sue my L&R, this info is all public on your website.
I'm curious. Is the ammonia solution miscible with the mineral spirits and naptha? Do you end up with a milky emulsion or a clear liquid like #111? Or worse, a two phase mixture?
Its a semi cloudy, the only think that doesnt stay emulsified is the dish soap. Checking my liquid now, the soap is at the bottom. I may need to try a new oelic acid, but they are all oil based so im not sure why its not emulsified. When actually cleaning though, it is emulsified.
Great thread, looking to make a UK version of the above, the hard bit seems to be getting the correct naphtha and white spirit:
From the L&R MSDS sheets the following are the ingredients for 111:
  • Mineral spirits = CAS 8052-41-3
  • Naphtha light = CAS 647-89-8
Klean Strip MSDS sheets (Not available in UK ?):
  • Klean-Strip Mineral Spirits = CAS 64742-47-8
  • Klean-Strip VM&P Naphtha = CAS 64742-49-0 (classified as light naphtha)
Note: A better match for the L&R 111 mineral spirits is Klean-Strip paint thinner = CAS 8052-41-3 (the same CAS # as L&R mineral spirits) They are both known as Stoddard Solvent
Now for the UK versions....
The closest I can get to Naphtha light is:
  • U-Pol S2001/5 Fast Panel Wipe & Degreaser (Link) which is the same as Klean-Strip VM&P Naphtha (both CAS 64742-49-0)
A little more detective work for the L&R Mineral spirits = CAS 8052-41-3, which according to Wikipedia is Stoddard solvent, and Stoddard solvent is a North American term corresponding to white spirit type 1. So white spirit type 1 is hydrodesulphurized heavy naphtha (petroleum) -> CAS 64742-82-1.
  • If we believe Wikipedia then we can find CAS 64742-82-1 as most common white spirits in the UK eg Bartoline White Spirit (Link) which is EC 919-446-0 = CAS 64742-82-1
  • I also found 25% ammonia (Link)
Drawing a blank on Oleic Acid... anyone out there have any ideas?
Scott, a quick google for “oleic acid uk” returns lots of it. It appears to be used in the food, pharmaceutical and beauty industries.
Tom
Good quality olive oil! That's roughly 70 - 80% Oleic acid (= the beneficial omega-9 mono-unsaturated fat in it).
5% Ammonia is 5% ammonia in water; to get 5% ammonia in your solution you have to start with a higher concentration, and water content will remain an issue. I make a water based solution (Finnish watchmaking school recipe) for clocks, that calls for 25% ammonia solution, which is mixed in with the rest, including oleic acid, until the solution (warmed up) just turns clear. Talking to my chemist friends confirms my guess that the ammonia and oleic acid combine to form a soap, not unlike mixing caustic soda and a fat to make soap (ammonium hydroxide has a ph of 12, caustic soda is 14, and oleic acid is a fatty acid).
The Finnish recipe is:
1L 99% isopropyl alcohol
3L distilled water
50g oxalic acid
60g oleic acid
and the ammonia works out to about 80g of the 25% solution. So I guess that means 20g of ammonia, which means about 0.5% in the ~4L of solution. Even with it "combined" with the oleic acid, there's a distinct but not too strong ammonia smell.
The commercial solution I use is from Greiner, and seems to be almost identical to L&R 111 functionally (it's quite popular over here), and it has a much stronger smell than the above Finnish mix. Looking at the data sheet, they have ammonium hydroxide at 1-2.5%.
As both L&R and Greiner state ammonia hydroxide, which is by definition a water/ammonia mix, the question is what concentration they are using. 25% seems to be the general result looking for "lab grade". How they get it to mix with the petroleum products is probably a trade secret.
Edited by nickelsilver
55 minutes ago, AndyGSi said:
Would the Dish Soap not act as a surfactant?
At best it will act as an emulsifier, giving a milky suspension like mayonnaise. #111 does not contain ammonia as one of it components. I guess it remains a trade secret of L&R as to how the formula is ammoniated.
Would sodium citrate possibly work as an emulsifier? I do use it for making cheese sauces and fancy cheese slices 😀
Tom
Tom
I think that only works with cheese.
It should pretty much emulsify any fat based product, so just chucking it out as an option as all oils are a “fat” of one type or another 🤷‍♂️
Tom
We've got a big bag of the stuff and a scratch made mac & cheese is sounding excellent for lunch...
I understood this to mean that the ammonia is to make up 5% of SwissSeiko's total volume, not that the ammonia purchased was a 5% concentration to begin with. I think the concentrated ammonia we can get in US hardware stores is 25%-30% so still plenty of water, but 5% of the total mixture consists of ~25% ammonia, so what, about 1%-2% of ammonia in the final mixture by volume? I think?
I have actual surfactant that I use for my lawn chemicals. I can give that a try if you think it'll work
It depends what type it is as some surfactants create a lot of foam to bond the 2 liquids.
I'll have a look later on. It's golf course grade so I would imagine it doesn't make foam
54 minutes ago, nickelsilver said:
While I appreciate the effort, is it really worth saving 50% minus the work, to have and use a cleaning solution that might be as good as the commercial stuff?
Of course what you are saying makes complete sense, but I see this as more of a challenge, a mountain that must be climbed 😀
Tom
Hmm cheese and biscuits at yours this afternoon Tom 🙂
How about distilling the ammonia aqueous solution ?
Haha some of us have that nature to knock our balls out to achieve something that makes little sense...just for us to have the satisfaction of saying....." I did that "  😅
So the ammonia.....does it actually remove dried up oil, dirt,grime etc any more than a non ammoniated cleaning solution or is it just a brightener or is this just a really stupid question and " of course it does "
It's a powerful degreaser, it converts oil & grease to a water miscible "soap" type substance.
I'm guessing the commercial L&R stuff it made by adding gaseous ammonia directly to the solvent mix under pressure to saturate it, so no water is added??
Restoring mechanical watches in general.
The only issue I have with this, is that it states it contains ammonium hydroxide, which by definition is ammonia and water. I'm still trying to figure out a way to emulsify the mixture. Canola oil has a very high amount of Oelic acid, so I may try that.
That is totally logical. My though process was, I have all of this stuff on hand, so why not try to make it myself!
That's correct, my ammonia solution is 5% of total volume. I ran a previously cleaned movement through the solution, and the solution was nearly black when in came out. However, it did remove a small amount of gold paint on the barrel bridge, but I'm not 100% sure if that was already worn off before cleaning, so just a note I'll need to monitor.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
    • Hello, looking forward to participating on the forum here! I will mostly be listening and asking questions since I am an amateur hobbyist. I have most of the beginner hand tools and a Timegrapher. The extent of my tinkering consists of a successful Seiko 7S26 to NH36 movement swap inside an all original 1997 SKX007, along with a bunch of battery changes for friends and family. I have yet to tackle full disassembly and cleaning. Right now, I don't really have the budget or time to invest in a cleaning setup (even manual cleaning), but hopefully soon! I joined because I recently purchased a mechanical Timex Camper from 1994, and my searches for information regarding servicing and swapping out these Timex mechanical movements consistently led me to Watch Repair Talk. There is also a wealth of knowledge here about dial design, another area of interest for me. My other hobbies includes leather working (mostly small pieces, shoes eventually), crochet, sewing (would love to make clothing), design (especially type design), home espresso, cocktails, and tennis. I want to buy a film camera, but I don't need yet another expensive hobby involving last-century technology. Yes, I have ADHD.
    • HWGIKE#60 Accurist ETA 2390 Swiss lever, 21 jewels, full service A slim Accurist with a nice movement, eventless service, nice performance.
    • Hello and welcome from Leeds, England
