Similar Content
This has to be the answer (nickel-plated). Nothing else makes sense. I'll try to find a more appropriate container. My next thought was to have a heavier insulated brass pot. That will take some heating, but then it should be very stable and hopefully will stop the heat loss.
The calipers are meant to give you some confidence if your experience doing this is limited. It can help you by giving a visual feedback/result. I kinda doubt if Nev is using calipers himself 😉
By nevenbekriev · Posted
You don't need to measure anything. All You need is to adjust the caliper for the 'thickness' when the shim is placed and fix the caliper not to move. Then remove the shim and adjust the bridge without shim as to be with the same 'thickness', and not to care what the caliper reads at all. -
By Twodogmike · Posted
Greeting all My name is Mike and I’m an hobbyist watchmaker from New Zealand. Have been down the rabbit hole for three years. Love hunting down old watches and fixing them to the best of my meagre ability. Cheers Mike -
Calipers are so that I can measure how much I’ve bent the bridge (if at all). I plan on being very conservative in my application of force, and if I’m only bending by tenths of a mm, I can easily imagine not applying enough force to bend it at all.
