So I received the Seitz tool from ebay but one of the two index pins that are under the micrometer is stuck in its hole. They have a spring under them that pushes the pin up as the micrometer is screwed up or down.
I tried putting a drop of oil in and then a drop of liquid wrench, let sit overnight hoping the spring would pop it up but no joy. I tried heading up the outside a little with a hair dryer and then with a screwdriver turned the pin left and right a bit but nothing. the fact that I can turn the pin says it's not seized up.
I suppose the Swiss make a watch size easy-out but there must be a better way. Any ideas?
22 minutes ago, Klassiker said:
I had a similar problem. See here:
Ultrasonic, didn't think of that.  I'd be a bit concerned about the finish but pahaps 2 or 3 minutes in a water solution would not hur it.  Thanks, I may give it a try.
10 minutes ago, AndyGSi said:
Drill a small hole in it and then either use a screw extractor or wedge a taper in it to pull it out.
Ok, so I took the smallest drill bit I had and drilled down and after a bit it came out, spinning with the bit.  Thanks. I actually drilled through the top and into the cavity where the spring rests.  No big deal and I can always shop for a spare.
The only thing I think I need to do is somehow clean out the hole a bit.  It's 4mm and both pins are a bit tight in spots as well as a pusher I tried from the set, so there is corrosion or dried up oil on the cylinder walls I guess.
Any idea how to best do that?
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
