TouchTiming.com based in Cairo, Egypt.  They have a tool I was interested in at a very reasonable price.  Shipping costs were also very good.  Does anyone have experience with this supplier?  I want to be sure before I plunk my money down.
Thank you!
Roger
Thanks for your repy/input.  I decided to email them with a couple of questions I had regarding the tool I was interested in.  It's been over a week with no reply so I decided against ordering from them.
Cheers!
Roger
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
