Hi,
I want to buy a starting tools such as loupe, tweezers, movement holder. pad etc. and I see that Aliexpress has all I need but I always sused that those are chinese replicas although they look exactly like the real thing, for example:
https://www.aliexpress.com/item/1005005099022972.html
https://www.aliexpress.com/item/1005005742598746.html
https://www.aliexpress.com/item/1005005108369510.html
https://www.aliexpress.com/item/1005006391855291.html
can I count on the site credibility that those products are original? I know that Amazon is an option but shipping is way more expensive since I'm not located in US nor EU.
Thanks!
Welcome to the forum.
First thing is if you're just starting out with watch repairs then I wouldn't start off with expensive tools like Bergeon.
Personally I wouldn't trust anything that's branded from AliExpress when there are genuine suppliers where prices don't appear much different.
https://www.julesborel.com/products/tools-tweezers-bergeon-tweezers/bergeon-7422-pm-b5-tweezer-brass-non-magnetic-alloy
https://www.julesborel.com/products/tools-movement-tools-movement-holders/bergeon-4039-movement-holder-3-3-4-11-ligne
https://www.julesborel.com/products/tools-movement-tools-movement-holders?search=2611-tn-2.5
https://www.julesborel.com/products/tools-bench-accessories-bench-mats/BG6808-GREEN
The Chinese are masters at counterfeiting. Stick with someone stateside so if you have any questions, you can call and talk to someone.
Esslinger.com is another decent place to buy tools. Pretty good prices and their service is great.
I rarely buy new tools now , mostly vintage secondhand tools bought from carboot sales , ebay or auction houses.  The older stuff is so much better quality than anything bought new.and often cheaper. For example i have just bought 5 pair of Dumont tweezer ( ok not vintage but i did say mostly 😆 ) 3 of these are duostar and dumoxel , a really unusual ruby jaws poising tool, brass pocketwatch movement holder, and handful of lathe accessories and a rack of 12 arbor vices for 150 quid inc delivery. It takes time to build your workshop in this manner and some restoration can be needed but thats part and parcel of this game, the upside is the cost and excellent traditional quality tools that were designed with the user in mind and they work as they are supposed to instead of a modern chinese manufacturer guessing what they are supposed to do. Other than that making what you need, bench mats, cushions, probes , tool holders, hand tools,  parts washers, have a look at our tips and tricks, diy and homemade threads. A little inspired ingenuity can go a long way to saving you a lot of dosh plus you get to make something custom that is suited to you and how you work. This hobby doesn't have to be super expensive, only if you let it 🙂
If you live in Europe for example the UK, Monaco, Moldova, or Norway, I'd suggest CousinsUK.com. That's where I go whenever I buy new stuff. Good prices.
As you are new to this I suggest you go slowly before making a substantial investment. Start with a decent...
  • work mat,
  • case holder,
  • case opener,
  • movement holder,
  • screwdriver set,
  • tweezers,
  • hand levers,
  • hand-fitting tool,
  • cannon pinion remover tool (perhaps not necessary)
Now you can take apart and reassemble a watch to get a good feel for it. I don't think I missed anything essential but if so others will fill in.
Edited by VWatchie
I forgot to mention that some sort of magnification is needed when you get started. In the beginning I only used magnifying glasses and I still do but now I have loups and a stereo microscope to complement.
Here's a post I wrote about it when I had just started:
https://www.watchuseek.com/threads/would-this-stereo-microscope-help-me-do-the-job.4468922/?post_id=43623827#post-43623827
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
