I have been slowly working on a Hamilton 992 and trying my best to do it right as it will be a gift eventually. I am getting fantastic performance out of it after poising and the escapement is working exactly right.Ā  But there is no shellac I can see. None on the roller jewel and none on the pallets. I only noticed this when I had the hairspring off for static poising. I cleaned the balance and fork by hand with naphtha months ago so I doubt I dissolved any shellac away back then.
But I know at some point in history impulse jewels could be friction fit. Is there any chance a 1920s Hamilton railroad movement should NOT have shellac on the roller jewel and pallets? I am prepared to add shellac but I don't look forward to removing the hairspring again. Everything feels firmly attached and in place already but I can't have this watch fall apart after it leaves my hands.
PXL_20240824_210630046.thumb.jpg.9d41200f2082ef3e2d7ca36e9507c9ff.jpgPXL_20240824_210607996.thumb.jpg.0359231507aa019b08089c25031b6ac8.jpg
In the few ads out there with a pic of the underside of the fork most look like yours but one shows shellac. Other Hamilton models like 912, 956 show stones without it. What does your check of the firmness of your settings tell you?
I think it only tells me that I am unable to move the pallet stones by grasping them with tweezers and gently wiggling. On my other old watches where they were not secure, they moved readily out of flat with the fork but I hesitate to push harder. Same for the roller jewel, not movable by wiggle or push. The roller table is copper in color and has the look of a complete part manufactured and meant to be replaced as one.
I have also looked over the sale listings and noticed the same, a couple have obvious shellac blobs but most do not.
I am leaning toward this being their correct manufactured state, but will still hold out for a yes/no from someone who has worked on a lots of American watches.
4 minutes ago, rehajm said:
No shellac on the pallet stones…
Gorgeous watch! And that's a helpful confirmation thank you.
I would do both but you should at least put shellac on the roller [it doesn't have to be removed to do it with tool], it takes a beating and is easy to loose and hard to replace with correct size, the hairspring will come of easily....
some say if it ain't broke don't fix it though....
Edited by CYCLOPS
I've been thinking the same and I probably will add shellac to the roller. The hairspring collet is very tight and difficult to get dressed screwdrivers under to remove. I have done it once before but really don't want to damage it. I should look for some hairspring levers.
I have a vintage roller table warmer of the spring clamp type, and the drawing on the box shows it in use with the hairspring still attached. But trying that on lower grade watches, I have never had the dexterity to get shellac onto it while the hairspring was sitting above.
if the hairspring has a slit in it some use a small screw driver to wedge and open slightly twist/lift off....be sure to notice/mark where the stud is to keep in beat
typically on these watches the roller jewel's friction and in no shellac is required. The pallet stones that I would be concerned about no shellac but I don't actually know whether they came without shellac originally. I don't feel like taking my 992 apart to see
then never ever use a screwdriver. The tool is supposed to drop into the slot and just fit. so in other words the tool itself has aĀ  very very long gradual taper and just drops in. Because anything thatĀ  is a wedge to open slightly risks damage. so yes drop in twist it will stay in place and gently pull up you can remove the hairspring collet without damage. Or just turn it without pulling to put the watch in beat
Thank you so much for the confirmation. The precision of the roller assembly did make it look like a factory friction install. I'm happy not to remove the hairspring again because it is now perfectly in beat.
I am going to keep researching the pallets. They also look very perfectly fit but I really don't want them to dislodge later. NAWCC may have info.
šŸ¤”.... The Collet that the hairspring is attached to, careful with opening this up, or you might need one of these to close it up again,Ā  or worse break it halfĀ
These look kinda nice, i use two crafts knifes that i changed to a bevel on just one side but they're a little too big and sometimes still too thick atĀ Ā 0.4mm . Razor blades will get you down to 0.2 but you could also make a pair using an old mainspring that will get you to around 0.1mm and a width that wont need reducing.
It was such a good idea i had to make a pairšŸ˜…
And they're rigid enough for the task? Great idea.
Razor blades didn't occur to me and I had a pile of them right on the bench. Next time. I won't be attempting to open this collet. It's the most well built watch I have seen and I want to keep all its tolerances.
I'll let you know as soon as the glue has set, just regular clear nail varnish to set them into a slot made in the pegwood . I'm hopeful that they will be rigid enough šŸ¤” tbh i think the mainspring needs to be bigger, i had 20 mins to spare so thought I'd give them a go. If not then a cut down razor blade will be next to try. The mainspring formed its own curve to aid getting under the hairspring when i snapped them, that was a bonus.
Yep rigid enough for this job. These work a treat as mini levers, bending the mainspring to snap the pieces i wanted from the straight center portion of the spring gave them just the right amount of curl to fit over the balance wheel rim and under the hairspring and collet.Ā  So the handles are 3mm pegwood which feels about right maybe a touch thicker might give them a better feel. A 0.2mm diamond disk cuts the 10mm slot in the pegwood to slide the spring into, fill the slot with clear nail varnish insert the pieces of spring, and run a bead of nail varnish around the slot and a little onto the spring, set them aside for a couple of hours to cure. When set add a bevel to the top edge only and remember to remove the burr created on the backside, using a fine diamond plate,Ā  fine finish the edge with dental strips, i guess the xfine is around 3000 @HectorLooiĀ might know what the grades of these are. Finally polish up with polinum on a sponge pad add a drop of oil to either the polishing pad or mix it in with the polinun,Ā  job done šŸ‘. The spring measures 1.1mm x 0.7mm, i left around 8mm showing from the handle, its actually a tad long but works well, 5mm might feel a bit better.
So you used a modern alloy spring with an S curve rather than old chonky carbon steel?
šŸ‘a modern spring has better elasticity, i picked the center portion of the spring to use. Dont try to cut these, they'll bugger up your pliers or grap your cutting wheel. Hold in straight pliers and bend them over then finish off using your fingers to bend fully over, nip tight and they will snap more or less where you want them to.
When the pallet stones are fixed without shellac, they are put to the bottom in the slots (just like the pallets on the pictures here). When shellac is needed, then the stones don't get to the bottom, otherwise regulation will not be possible. Of course, applying shellac will not do harm for sure.
I have absolutely no idea. Most dentists are not very technically minded. As long as it gets the job done, we don't care. 🤣
No worries hector i guess the same applies here, if they file and leave a smooth finish thats all that matters .
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022. Ā The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss. Ā Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases andĀ  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could releaseĀ  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?Ā  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
