New High Res Oiling Video
SSTEEL
Old video, but new high resolution, I asked them recently if they had a better quality video as the old one was pixelated.
Thanks for this, I also viewed Part 2 and that prompted to get my oilers out for a good look.
I'm afraid I have a bit of work to do so off to the garage and a fine stone and some 1200 wet and dry and maybe some Brasso.
At the moment they look like this (stuck to double sided tape so they look a bit strange.
More to follow after I've refined them.
Cheers
Jim
Edited by JimInOz
So after some time in the garage, my cheap Indian oilers (Anchor brand) have had a polish.
I'll give them a go and see if they improve my oiling skills.
Original Oilers
post-1141-0-24026000-1446509904_thumb.jp
Polished Oilers
post-1141-0-95280700-1446509558_thumb.jp
Edited by JimInOz
The top pictures are definitely not a good look Jim!
Have you tried the polished ones yet? I'm interested to here your comments on the difference that the polishing makes.
They came out well, how did you polish them, via hand, or buff?
I started with a fine file, then 400 paper for shaping, fined off with 1200 paper and finished on a small felt wheel on my Dremel.
The tips will still pick up big drops of oil. With practice I found that the "lift" out of the oil pool can regulate the size of the drop, as can wiping on the edge of the cup.
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
