Hi, i am still quite new to watch repair, but got my hands on a beatiful Omega Seamaster.
When i got it a year ago, i took it to a jeweler, because i wasnt working, he just told me it wasn't worth fixing. unless it had sentimental value.
Then finally i have been learning and repairing some mechanical movements, but as this is a quartz, i am abit lost. The watch runs and keeps time after i took some of it apart and put it back together, but when i wear it, after like 1 hour or something maybe less, it stops. Does it just need to be cleaned and lubricated again. or could it be the stepper motor, i couldn't really find out if it could run with a Stepper motor that isn't working properly.  i have also noticed that there is no movement clamps holding it in place, could that also cause the problem, when the back is on, it doesnt seem to move or anything.
I expect it does just need a good clean and service.
Can you confirm what battery you've fitted?
Edit
Case clamps shouldn't make a difference but would be advisable to get some if you get it working.
Edited by AndyGSi
Thanks Andy, i was also just expencting a good service, it just supriced me as a "Watchmaker" told me it was not worth fixing, if its just a service. Maybe he is just not very qualified. as i assumed he was. Richard, here you go i had 2 pictures af the front 🙂
It probably the fact that not a lot of 'watchmakers' work on quartz or it
maybe because of what he'd charge for a service it wouldn't be worth it.
As I side note, the dial doesn't look right to me, what's the details on the case?
I would fix it if it were mine.  Early jeweled quartz watches are cool, and it is an omega.
My first guess would be there is an issue with electrical contact.  Make sure all of the screws in the electrical path are making good contact.  Check to see that the battery contacts are clean.
After it stops, can you start it by just jiggling it around?
Except for the calendar works, this looks like an easy service, but you should not attempt it until you develop your skills.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
