A friend has asked me to look at her Omega watch saying that it seems to keep stopping. It runs to time on the bench for 12-13 hours: is this a normal power reserve for this size/type of watch? (it's 2cm+ diameter but no indications of the model are visible - I daren't try opening it as it looks like it needs a proprietary tool to do so)
Yes, Jaxa tool or the rubber ball.
Calibre 630 seems plausible. I recently fixed a 625 (similar to 630, but without centre seconds) and the size/design are similar.
12-13 hours isn't enough, without question. The cal 630 should do 30h and I believe that's pretty much the lowest you'll find.
  On 7/22/2024 at 4:49 PM, RichardHarris123 said:
We need the caliber to know the power reserve.  If you're not willing to open it, how can you help her?
Expand
At this stage I think I can best help her by not opening it (I don't want to scratch the back for a start !) & passing on the advice on offer here!
  On 7/22/2024 at 6:14 PM, Nucejoe said:
Jax tool would work just spread a plastic sheet on the case back.
Perhaps cal 630.
Twelve to thirteen hours power reserve is low.
Expand
Thanks, that's helpful.
Perhaps cal 630.
Expand
In parallel with seeking advice - and thanks for all the responses - I've been recording the watch power reserve each time I've wound it and over 5 days that has doubled from ~ 13 hours to 26 hours, presumably as the watch has 'run in', it not having been used for some time. During this monitoring period I was thinking a new mainspring might be required but I think the fact that it now runs for more than a day might makes it once again a practical timepiece for my friend.
Expand
Sounds like it needs a service.
Expand
You don't usually need to change the mainspring.  I'm currently testing a cal 625 I just serviced. The hairspring looked a little 'tired' in the centre coils, but I thought I'd try it.  It's giving a healthy 290° amplitude (240° after 24h) and power reserve of about 40h (spec is 30h).
Expand
The fact is I'm at a very early stage in my Watch/Clock tinkering and don't have the confidence to address a relatively high-end marque that isn't mine when it can be 'improved' sufficiently without any risky intervention. The owner now feels that the watch is a practical timepiece for her as I've shown it didn't just 'stop running' randomly & was thus unreliable which had been her impression leading to it being unused for some time & why she asked if I could do anything to help. I will, however, pass on your comment that it could nonetheless do with a service.
Expand
Wise words. So many think it will be easy, and end up damaging nice watches (despite warnings). The Omega 620/625 are nice simple movements, but just their small size makes them fiddly for beginners. Good luck with your tinkering. One day you will have no problem servicing such movements.
    • ??? The cannon pinion, which is your minute hand post, also drives the minute wheel. Then through a series of gear reductions drives the hour wheel ( hour hand post ) at one 12th of the rotational speed of the cannon pinion. I can see these connections made in your picture. With some wind put in the barrel both cannon pinion and hour wheel will be moving if the train and escapement are actively working. Put on the dial hands to quickly varify that.
    • Good entry level movements , Ronda,  miyota,  Seiko . No overly expensive either.and some service information available.
    • Thanks guys for your input ...Tried various ways but Kalanag gets first prize. It is screw back so I have removed with minimal damage. For anyone else who comes across this type of case back I've added a picture of the removal tool. Mind you it doesn't do the compass much good.
    • Hello. I wanted to follow up with a few more pics in case it makes sense to anyone. The first image with the tweezers shows where the seconds wheel passes through. This is the only part that will move when wind the watch. This tube is fixed to the plate and is not movable. I can put the cannon pinion in here and it will engage with the barrel wheel directly. Putting the dial side wheels in order still gives me no idea how the minute and hour hands are supposed to move as the only direct contact is still that wheel that is part of the barrel wheel. Any help would be appreciated.
    • Hi everyone, Not sure if you can assist, but here goes. I am trying to replace a few parts on my father's Rado DiaStar: 129.0266.3The crystal gasket over time has softened and melted inside the case/crystal. Additionally, when I removed the movement one of the electric contacts came off. In the attached image, the small gold fingers is what I am referring to. The electronics and movement are beside it. Where in the movement does it go? Additionally, I would like to find a set of replacement gaskets for the case/crystal and case back. can you assist with that?
